Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
starcruiser
No problem Tony, I was asking since you might have already done some of this. If not we can try it too. I will start when I get home, I am currently at work so not much I can do yet. :)
Regards,
Carl
teslaalset
Can anyone post the circuit diagram if known?
Thanks
Paul-R
Quote from: Operator on January 05, 2010, 02:44:32 PM
2. Where the hell the energy comes from?
There is no shortage.
Check out this awesome free ebook:
http://www.free-energy-info.co.uk
Google for:
1. Hal Puthoff,
2. the 1957 Nobel Physics prize
3. Westinghouse and their Minuteman Missile patent
We are living in a soup of energy. It is a matter of connecting to it.
starcruiser
There is no circuit just a coil configuration and how it is wound.
Input low voltage low amps (mA) he is using 31vdc @ .09A (90mA) and getting over 1KW out
Current issue is the BEMF (or ???) to the input drivers which causes failure due to over voltage/curent. Read the thread for more on this.
Regards,
Carl
teslaalset
Quote from: starcruiser on January 05, 2010, 04:09:45 PM
From what I understand there is a circuit that consists of more than just a set of coils.
This is what I derive from the earlier descriptions:
- A pulse generator drives a fet driver
- The fet driver drives three FETs that are connected in parallel
- The three drains are connected to one end of the primary winding
- The power source is connected to the other end of the primary winding
- A secundary winding is wrapped around the primary winding and holds a load.
I wonder whether there is any flyback diode used to protect the FET(s) against the large voltage occurring at the drains right after switching off the primary coil....
The description of the output power is still vague.
It's not said that the output is > 1KW. It says 'it moves > 1KW'. Probably to the switching fet(s), instead of the output.
I'll have some more patience to see what exactly the input / output configuration is.
