Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
hartiberlin
Hi Mannix,
only the area below the pulse which is higher than zero counts, as this integrates to real output power.
If it is just only a needle spike pulse and all other time zero, it will not bring you much output power and
will not run your lights.
Magluvin
I do agree with Stefan as to finding the resonance of the primary, but that freq may be very high due to the length of the wire and no of turns. Or do we need to find the resonance of the secondary?  I only say this as 100 hz would be far from being close. I dont have a sig. gen. I will have to use a 555, measure the freq and apply to my primary. I didnt measure my primary for thickness but I assume less than or about .1 mm. Thin like thread. I will measure the ohms tonight and work on the circuit. This tube should provide similar results with 45 deg crossings without wondering what the web is doing, and if this shows nothing then try a prescribed coil with the inner primary touching the secondary.
Even if this doesnt work there is maybe some things to learn about the spaced windings and how cross wound coils react, even if the crosses dont touch.  Its fairly easy to make these things. They dont have a 1000 turns. And there are many combination's and angles to try. Teslas coils seem to be this way with space between the windings, and I believe it is for capacitance reduction in tuning. But maybe something else.
But resonance seems like a factor that is going to play a part. But if tonys end product does as he says, then resonance , as we know it will be ac, and tonys is a continuation of dc, which could still be a resonance effect, but a resonance of the spinners vibrations that keep them spinning in 1 direction. Dem unknown lil spinners.
Magthinks
Magluvin
Mannix, hey loved the show when I was a kid. =]
Can you push up the freq to allow the large on and off time to be filled with those lil ringdowns. It would be interesting to see what happens when the freq is high enough that a new pulse happens before the ringdown is over.
Magthinks
Mannix
@stephan,
Perhaps perhaps not but to see this pulse is the first step to Tonys revelation, and it is quite large.
Thats why Im perplexed as to why, when i step down a range , i cant see it at all, just the tiny spikes again.
I cant do any more tests untill tonight and im not looking for power at this stage anyway.
WE need to see this effect BEFORE looking for reasons why it wont work.
My goal is  to get to first base which has been a challenge.
One step at a time but I can at least see what he is on about..now and almost by accident.
Every one must fiddle with their cros a lot more than usual.
Sure it may turn out to be something weird with the cro ..I will find out .
btw my current coil is reverse wound  but cant prove that its important yet
turbo
http://universalpower.webs.com/myvideoplayer.swf
A small collection.
Think about all that hard work,time,money....
Result?.....0,0
Endless story, people want to be fooled..When will they realize?
I bet Steven is laughing his ass off..
M.
