Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
Mannix
You need to at least see pulse ..it is different.
Im not saying any thing else at this stage, it could turn out to be not what i would like,
I dont care but i will look regardless of failure ..the real failure is to give up trying even more to suggest other's  give up.
Tonys tpu may or may not be the whole picture ..it is not intentionally misleading or fake.
That is more than can be sais for many of the past units.
succeed or not ...power or not this pulse needs some investigation.
Super God
>9000
Magluvin
It would be nice if the lil spinny things did the do.
But I will try something with this new coil. wut it do.
Mags
wattsup
@marco
That was fantabulous. So many TPU builds. What a job and a half. Hey, do you have some stray builds I can play with. It was interesting to see all them wires just jumping out the center of the tpus, showing all those many wire endings one would have to contend with, and this teaches me the SM TPUs could not have had so many just from the visual and build perspective.
@all
Apply a steady 5-10 vdc to the primary and do a mapping of the field polarities with a compass. Then reverse the connections and see the reverse in the fields. You may need to tilt the unit sideways to effect the compass. Make a drawing showing the fields. Do the same for the secondary.
So, you need to know the north/south field relationships regardless of the pulsing voltage and/or frequency, this will be the base line or how the muscle works.
See where is the primary blotch wall? Most likely in the center, so don't put your secondary there. Try 3 turns in top half, the fourth crossing though the blotch and 3 turns on the bottom half. Or put two secondaries then in series or parallel, or each alone, does not matter.
Try 10% duty, not more, you don't need more because chances are any more will not change the outcome given the low total copper mass of the primary.
Try capacitor discharge into the primary. Meaning charge cap, discharge cap into primary, and so on. Put a dioded cap on the secondary and see how much you catch per pulse.
If you have the three phase primary, do a RV type set-up. 2 phases driven on two pulsed wires, with 3rd phase in parallel through a very small run capacitor.
There are many things you can test.
Magluvin
Agentgates  Agentgates,  this is Magluvin 0 7    We need you to come back to base.  Project spinertia is being twarted by the Coil Finger group. We need those videos Gates!  Get back to base!
Magluvin 0 7
