Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
IceStorm
Quote from: wattsup on January 11, 2010, 11:59:11 PM
@marco
That was fantabulous. So many TPU builds. What a job and a half. Hey, do you have some stray builds I can play with. It was interesting to see all them wires just jumping out the center of the tpus, showing all those many wire endings one would have to contend with, and this teaches me the SM TPUs could not have had so many just from the visual and build perspective.
@all
Apply a steady 5-10 vdc to the primary and do a mapping of the field polarities with a compass. Then reverse the connections and see the reverse in the fields. You may need to tilt the unit sideways to effect the compass. Make a drawing showing the fields. Do the same for the secondary.
So, you need to know the north/south field relationships regardless of the pulsing voltage and/or frequency, this will be the base line or how the muscle works.
See where is the primary blotch wall? Most likely in the center, so don't put your secondary there. Try 3 turns in top half, the fourth crossing though the blotch and 3 turns on the bottom half. Or put two secondaries then in series or parallel, or each alone, does not matter.
Try 10% duty, not more, you don't need more because chances are any more will not change the outcome given the low total copper mass of the primary.
Try capacitor discharge into the primary. Meaning charge cap, discharge cap into primary, and so on. Put a dioded cap on the secondary and see how much you catch per pulse.
If you have the three phase primary, do a RV type set-up. 2 phases driven on two pulsed wires, with 3rd phase in parallel through a very small run capacitor.
There are many things you can test.
I don't get your point here. Why test some variation ? There a claim here , if no one are able to replicate with all the information AgentGates gave to us, there 2 possibility: We cant replicate it because there a special component missing OR the first idea is just wrong, in either case, there no need at all to try modification , we don't have ANY indication of what is wrong and no proof of concept AT ALL from a working prototype.
Best Regards,
IceStorm
hartiberlin
Quote from: -[marco]- on January 11, 2010, 07:29:47 PM
http://universalpower.webs.com/myvideoplayer.swf
A small collection.
Think about all that hard work,time,money....
Result?.....0,0
Endless story, people want to be fooled..When will they realize?
I bet Steven is laughing his ass off..
M.
Hi Marco,
great builds and much work.
Would be still better if you had posted more documentation
over the years. Then some people may have had some
more ideas how to help you.
Many thanks for this compilation.
onthecuttingedge2005
Hell, I did this 20 years ago, wrote them on diagram with art bell, nothing special . just a certain transformer of curiosity.
that is all they are, transformers, a transformer will behave as such, a transformer.
turbo
For the record that video contains only a slight selection of what has been done....
Quote from: Mannix on January 11, 2010, 08:38:33 PM
the real failure is to give up trying even more to suggest other's  give up.
Bullshit Mannix
It's a failure to continue with this never ending joke.
There are other devices that have been well documented and video's wherein the inventors actually describes and shows the entire process.
This gives you a definite direction and you instantly know what to do and where to look for..
Compare this to what we have been doing over the past years and the TPU becomes dust at once.
Once you start looking around you will quickly realize that we all have been shooting in the dark for many years with this vague TPU Device.
Nobody knows how it works or what it does or how to build it.
The inventor isn't very helpfull ,And it is going to stay like that, trust me.
Nobody is going to solve this one in a hundred years.
I am glad i decided to look around and see what other great things have been done in the past.
It's not a failure to see if it's possible to switch route to more clear roads, I found it's actually a good decision.
Marco.
IceStorm
Quote from: -[marco]- on January 12, 2010, 01:12:00 AM
Bullshit Mannix
Marco.
You know what its realy funny, no one ever asked themselves "What if the toroidal form as nothing to do at all with the effect" , that will explain why he didn't care to let people disassemble the core but NOT the circuit.
Lol ,
Best Regards,
IceStorm
