Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
agentgates
Quote from: SPP-48 on January 13, 2010, 12:46:28 PM
Hi Tony
Using the formula gives me a height of 41.89mm for an 80mm diameter tube. Is this correct. I recall you were using a 70mm high coil originally.
l = (80 x 3.142)/6 = 41.89mm
Cheers
Sam
Hi Sam,
Please ignore my very first coil I posted (70mm length). Somebody suggested a 45 degrees on sides to try, I did and was doing well so we agreed to stick to the 45 as a "standard" thus everybody will get the same coil and we can minimise the chance to make a mistake. Later we will vary every parameters, but for now we stay at the 45 degrees.
Yes, BTW the ~40mm is correct. ;)
minde4000
@agentgates
Your formula for 45 degree angle is incorrect.
Check my last post withdrawings.
In order to get 45 degree angle in this particular case:
R = H (radius = height)
Minde
Magluvin
Ramset
I know. It is hard to hear a couple more days after a couple more days, thats all.  Its almost like having a missing person in your life and being told that they were found but keep delaying the homecoming again and again.
And Im sure we are all anxious. I worry about it all being manipulated before the real deal makes it to the plate.
Now if I had Natasha, you know the hot russian chick in my life raft that we escaped in after Coil Fingers superconducting boat of doom exploded, I would send her over to to give gates a pep talk.  lol
Hop grasser
Magluvin
Well I gota head out. Hate to miss anything.
Magluvin 07
agentgates
@Minde
No, my formula is absolutely correct. ;)
http://www.samsonium.org/sites/default/files/P1130294.JPG
@Magluvin
Ramset is right. So please be patient. :)
BTW, this is the sequence on that track you're about to get us to join you. They are each a cause of the the next one in the list:
1. Overexcitement.
2. Impatience.
3. Rush.
4. Skipping important steps.
5. Mistake.
6. Failure.
7. Loosing your energy.
8. Turning back.
9. Keep repeating the above process until the big turn:
10. Loosing faith in what you are doing.
11. Need to protect yourself against others critisism.
12. Blaming others for your failure to protect your social rank.
13. Depression.
14. Worse...
It is a well tried out way and you don't need to go too far to verify it, just look around on this site and/or watch Marco's video. A very good lesson.
Be a perfectionist and don't get overexcited when you have a little success! If they are each a cause of the next one you can eliminate all of them in the list by getting rid of the first one.
UPDATE
Need to get a 2-3 hours rest guys, my heart is not doing well. I'll be back right after and hook it up.
