Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
Quote from: agentgates on January 13, 2010, 07:16:45 PM
@broli
Thank you for your ambitious work again. :) However I can not see change on the page.
I can not modify my first post. :( There are many things I would like to change there but somehow the "Modify" button disappeared.
Try hitting Ctrl+F5. Ask Stefan for updating the first post. And don't burn yourself out, eat and sleep healthy. Free energy and health should be both important to the tinkerers here.
ramset
Tony
Hook up the vent
the glue will affect you!!
don't just open a window get the vent going PLEASE
Dryer vent hose, small computer fan stick the hose out the window put foam/pillows around to seal
Chet
Broli
you can PM Stefan to add that info to first page
Thanks Grandma
plengo
Quote from: broli on January 13, 2010, 07:04:38 PM
Ok the revised page is up, I hope all the parameters are correct now. The link is at:
http://ziosproject.com/NJ/AAcoilPres/index.htm
Perhaps this can be put in the first post so new comers can directly see the latest design?
Beautiful great work Broli, thank you.
Just for completion, since your one site for ALL info has the best coil representation, would you be able to also show there the wire sizes?
I have ALL the materials to replicate this work, including a programmable 14 channel micro-controller that I used for similar projects where I pulse coils such as this one. So I am dying to start but still a little confused (cleared by your 3Ds concerning the geometry) about the wire sizes.
Fausto.
ps: pdf below might be usefull for those trying to coil in such large cylinders.
Magluvin
Hope ya feel better Gates.  Glue can get ya. Car fumes get me good. Migraine. Starts with fuzzy vision then about 20 min later its a pounder.  More the cars that produce more carbon monoxide, due to no catalytic, bad catalytic, runs rich.
Was looking at scopes on ebay and a fairly descent one can be had for a reasonable price. I had one years ago but wasnt using it for a while and a friend needed one. So I sold it.  Gunna buy one.
Thats interesting about the voltage increase affects the outcome. The what it does, sounds out there, but I gotta accept that there are things that are not known by many.
Hop Grasser
tanakat
@plengo
The latest post I could find was this one :
http://www.overunity.com/index.php?topic=8586.msg221148#msg221148
Tony talks about :
0.19mm primary coils. Altogether 3 primary wound on the acrylic tube in the same manner. 45 degrees angle to the centreline and 10 degrees between the same primary coil. Each primary coil has 3.33 degrees offset to the previous one.
You can assume from the top of the post that the secondary uses 0.74mm
Hope it helps you
