Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
pauldude000
One other thing, before I forget to mention it. (please pardon my typo's... I haven't had any sleep.)
A new principle...
Magnetofriction: The drag placed upon a moving magnetic field due to resistance of motion.
Reduce the friction if possible, as it is like the proverbial merry go round with rusty bearings.
ELectroconstriction: The repellent force applied to electrons caught in between two separate nodes of a warped  or uneven motional electric field.
Something else to consider.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
Mannix
As few a more people spend a few hours and 20 bucks (assuming good equipment)
Peoples theories can be proven , duplicated and built on.
I have no Idea except that particles are being moved along wire as I have not seen before.
It is as perplexing as it is is  exciting
the field is above and below the unit but not much to the side.
It has a polarity and creates dc pulse  in  wire imersed in it
The loads seems to have little or no effect on the primary accelerator circuit.
The primary switch on time time must be fast.
It is not frequency dependant but frequency has an effect on how may pulses are there.
If this device can be syncronised with itself it seems many things might be possible.
placing an alluminium can in the centre kills the effect
Tonys explanation is still the best but it is ony for the purpose of visualization.
Untill i can see an electron or whatever they are ,I remain ignorant with the possibility that a better understanding on my part will develop.
Class has begun , now go and get some wire and a tube and join in with no expectation other than you will enjoy the process.
Wether this is ou or not is not important to me at this point
Thanks to all who are able to contribute
I will do some more this weekend  including the reverse wind
FatBird
Thank you for sharing your findings Lindsay.  I am getting much more output from mine because I am using stranded Speaker Wire on the outside for the Collector.  PLUS, I have many more turns of wire on it.  16 Turns of Speaker Wire equals 32 Turns in Bifilar Mode.
I think everyone here is missing the boat by using only 2 or 3 turns of wire on the Collector.  The SECRET is to use MORE TURNS in BIFLAR mode.
FatBird
Here is a diagram of Bifilar in case anyone is interested in trying it.  The benefits are listed on the photo.
teslaalset
Quote from: FatBird on January 14, 2010, 09:51:18 AM
Fatbird, can you be a bit more specific on your input and output power?
Just mentioning you have more is not helping anyone here.
