Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
itanimuLLi
Tony and Broli You are a great team tank You.
I am following the thread from the biginning and it has developed very professionally. I  see result from other experimenters that proves the theory behind this setup, i know a little about e.e. and this device is not a transformer. if it was there could not be any output. Again thanks for all the efforts, keep the good work and keep on posting.
Magluvin
Fatbird
Ya know, I did a vid on YT comparing a 100 turn bifi compared to a 100 turn regular coil and the back emf seemed no different than the other. I had played with those coils for quite a bit to see the difference. The only conclusion that I could come to was that the coil reacts differently at resonance, But I dont have the equipment to test that.
I had seen an experiment with a nail wrapped in regular and bifi and it said that the nail had more magnetic strength in bifi, but if it were true then the rotor I did tests on should have turned faster with the bifi with the same input, but there was no difference. So on that, I concluded that the effect must be during a resonant state if it exists.
I have not tried the nail experiment though and also my coils were air core, so with a magnetic core there may be some differences.
If someone could show me differently, I would be thrilled.
Mags
Rosphere
Quote from: Mannix on January 14, 2010, 09:26:50 AMUntill i can see an electron or whatever they are ,I remain ignorant with the possibility that a better understanding on my part will develop.
I was contemplating this device while driving into work today.  I think the secret may have something to do with the interaction of the expanding and contracting magnetic field loops involved in the 45 degree relative wire offset angle.  There must be some sort of twisting of the loops in order to cause induction on the collector.  Perhaps the response loop can not twist back in the same way, so maybe, it twists 45 degrees in the other direction.  All of this combined twisting and untwisting of magnetic field loops may interact with the (aether, cosmic background energy, vacuum energy, earth E-field, whatever you call it,) in some one-way vortex interaction.  It would be interesting to see an attempt to show these magnetic loop interactions using some software tool.
EDIT:  I had a similar idea almost three years ago.
http://www.overunity.com/index.php?topic=2240.msg29283#msg29283
Magluvin
Rosphere
There may be other angles that may be better than 45 deg. It seemed as though in the beginning that the angle wasnt 45 deg but then 45 was settled on.  From what I gather Tony had the effect before applying the 45 deg to the list.
Mags
Rosphere
Quote from: Rosphere on January 14, 2010, 11:12:50 AM
Is this even possible; twisting of magnetic loops?
Every graphical representation I have seen always shows magnetic loops lying in a plane.  Are magnetic loops planer?
