Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
Bruce_TPU
Quote from: Magluvin on January 15, 2010, 10:35:14 AM
That was cool Bruce. But we still have a 'hump' on a camels back to break.  The hump is the only plus I have seen and t states that in the sushi. Lol first post and then we have one replicator with humps.  Mags
There may be an actual interesting effect (not OU) to see, at least Lindsay thinks so.  And it is always good to learn.
My whole issue is the claim that this was somehow the SM tpu figured out.  And then the whole way in which things were handled.  De Ja Vu.  There have been many of these such incidents.  Melted IGBT's are not signs of OU.  MANY of the guys have melted them and more.  You would be amazed how the power supply can fool you.
Besides, a SM TPU will never work off of a power supply, too much noise, only test with a battery.
Funny, I know a man who blew a hole in his garage roof when his coil disintigrated.  LOL  Now that was OU.  But he never wanted to see that coil again...It shook him up, and understandably so.  Bob Boyce messed with a TPS or toroidal power system on an air core and was struck in his hand by lightening, with a lightening pole a few feet away at the corner of the house...Bob did not mess with that coil for a bit.  A friend of mine recently tested Bob's coil with his own controller and it was OU.  So, keep on testing...
Cheers,
Bruce
wattsup
@psm1963
Don't push your luck buddy. You are right at the edge and with so few posts under your belt, you can get banned right away. I suggest you simmer down.
@AG
I don't think I posted anything bad or derogatory. Just realistic. How else would you feel if you were in our shoes. @sushimoto did the right thing to put the post number 1 above. Read in your own words what you have claimed. But words and deeds to not coincide and you cannot expect guys here to sit around like ostriches with their head in the sand.
If you come here and say you have the answer, then show it. But if you come here to ask for help, then ask for it. But if you come here to expect guys to follow along in a zombie state, then we definitely have a problem.
It is all a question of perspective. Your perspective is to say one thing but show another and our perspective is to be straight with other members from the start. Saying you have the answers is not the same thing as then pushing guys here to do all this R&D with changes as you go. This does not spell someone who has the answer, but someone who is working with others to find the answer. There is a major difference here and this is what you do not want to acknowledge. You need help? Then be honest enough to ask for it and not go by so many side ways. Based on that openness I and some others would have also participated more actively in building and testing as long as we are all on the same footing.
We have worked with many people here that have openly come to show something new or out of the ordinary and guys here have worked well with those that ask for help. It is that simple. Just be  honest enough to state the real situation as it is and ask for the help you need. Otherwise, it would be best if you indeed go to your closed laboratory and not be bothered by the real world.
Kindest regards,
wattsup
MasterPlaster
Quote from: Bruce_TPU on January 15, 2010, 10:23:29 AM
And thus the saga ends
@Bruce
Hardly! I think this is just the begining. I had never been happy with format of the TPU that has
been spouted for so many years. It was something that someone came up with. I believe Tonys
Idea is the next stage of the evolution.
I would love to try your frequencies with a Tony style coil. Self sustaining rotating magnetic field might just be with our grasp.
In the mean time watch this video. It will blow your socks off:
http://video.google.com/videoplay?docid=-1523833666089029157&ei=QphQS7DFNMaA-AaJifChBQ&q=the+secret+of+universe&emb=1
Frederic2k1
Quote from: Bruce_TPU on January 15, 2010, 10:46:43 AM
Cheers,
Bruce
Hehehe, I'm thinking a long time about Bob Boyce TPU... is his TPU perhaps the real operation-mode to achieve OU ?
starcruiser
@psm1963,
finally found a thread you could discredit? go back to sleep.
Regards,
Carl
