Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
turbo
yeah yeah okay...you obviously didn't get the poynt..as usual
pauldude000
Quote from: gauschor on January 15, 2010, 04:05:14 PM
Please give me a hint, because from what I've seen most don't do OU, or can't be replicated due to various reasons.
@FatBird: chemtrails may darken the light a bit, still there is power from sun, as long as no one switches her off  :)
The TPU is real, if you can wase through the billion tons of purposeful dis-information which has been injected through the years. Just try for an actual rotating field, and not all the high voltage high power banging BS, that is unless you want to be a casualty.... That is up to you.
There is a device called a 'water hammer' which is demonstrated and measured as OU, dont know if the unit is being replicated here though. (Uses mechanical resonance to heat water to steam.)
There is a Hydrogen generator which works quite well, and the original was claimed as OU, and from my perusal, it used destructive resonance to separate hydro. The inventors name was either "steven" or "Stan" or something, been a long time since I examined the idea personally, but I keep thinking there is a replication effort here.
To many real inventors try to get "funding", and in so doing get tied up legally, all info unsharable with anyone, and the invention shelved. That is what happens when one gets greedy.
I will say there is more disinformation than usable information, you have to wade through the BS. If someone is asking for money.... run. If they are excited, sharing their results openly, then investigate further, but be prepaired to be disappointed.
OU has always been possible, the application of the conservation of energy law is what has been misapplied. OU is merely a greater efficiency than is accountable for in a DEFINITION LIMITED system. Basically, it uses forces other than are accounted for or are expected. Most energy in any such limited definition system is wasted.
For instance, you can put a battery in a circuit, and claim that battery is your power source...... What other energy forms and types may also effect that circuit? If you discount them as power sources, them you will have OU when one pokes up it's head.
Electrical Engineers have to fight this problem all the time in the form of anomalous circuit activity, and application of 'rules of thumb'.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
pauldude000
Quote from: -[marco]- on January 15, 2010, 04:26:47 PM
Me?
You guys still think it is poynting energy or flow. (Talk about the duh factor.)
You guys have 'toys'... Cool. Play with them. Thousands of guys have 'toys'.
You are not 'special', just merely egotistical.
Paul Andrulis
ramset
Thanks Grandma
turbo
Quote from: pauldude000 on January 15, 2010, 04:42:09 PM
Me?
I have never thought it was poynting energy or flow.
I wonder what makes you think that...(Talk about the duh factor.)
Paul Andrulis
So what makes you think that i think i am special?
What makes you think that i think it's poynting energy or flow?
And what makes you think that i am egotistical?
You have no idea.....
PS i love the pistol shrimp vid  :)
