Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
Spider
thanks tony,
This is how i have done the secondary. dont know if its oke. Suggestions?
Ill be posting my results on overunityresearch.com, in my bench, so i wont clutter up your thread any further.
Spider
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
I don't fully understand the "channel" thing. Are you talking about the channels from a mosfet or a channel representing one coil setup? So three in this case being the secondary of the first hooked to the primary of a second setup and so on.
Bruce_TPU
Quote from: Spider on January 06, 2010, 12:12:56 PM
thanks tony,
Spider
Hello Spider, my friend,
You need spacing between each of the turns on your secondary, according to the instructions.  do not let the turns touch!   ;)
Cheers,
Bruce
Spider
Hi Bruce,
I just read back some posts here and came across tony's advice yes.
I ll change it tommorow and hook it up to the IGBT's I have.
Are you replicating this too?
Spider
jox
Hi, the oblique felt tip line represents the inside wind of
the primary showing where the two primaries cross.The
horizontal felt tip lines represent the secondary coil
positions, is this correct.
regards, after many attempts hopefully this one works.
