Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
otto
@ramset
you said "no stone unturned"?
I found 1 that was not seen and turned.
Otto
ramset
Otto
Well Otto You deserve to find an unturned stone!!
One that has a reward,you have looked under many stones!! [Hard Work]
God knows this quest can drive men Mad.
Or close [poor Marco!!]
[Doctor says he'll be fine, Has to stay away from Coils for a while!!]
@Lindsay
Thanks
yes Paul said he would!![build it ,[Not a big job]]
Chet
No stone left unturned!
Thanks Grandma
Mk1
@all
Here is a test i performed , and may give some hints to why there is a toroid in the middle of the TPU, feed back to source , maybe , see ...
http://www.youtube.com/watch?v=Glg8ZWntnAo
ramset
Mark
Thank you for the movie.
I have no sound.
What do you think is the reason for the Toroids effects?
Chet
Thanks Grandma
Mk1
@ramset
The toroid i am holding is made 1000 plus turns of 30 gauge mag wire .
The led is connected to it trough a diode bridge , first you can see where the field is located in and around the TP.
Second , any circuit located in the center of the toroid acts like a receiver.
It is pretty hard to explain , i discovered this when working on a dual jt on a single toroid design .
What i have learned is that the second jt circuit on a shared toroid dosen't need to be connected to the battery , you could insert a cap instead , the collector and base coil from the second jt feeding it self . Since the primary acted like a secondary and feeding it self.
