Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
ramset
Mark
Thank you
I will watch again keeping your explanation in mind.
Quote;
feeding it self.
Do you feel some part is grabbing power from
a source other than the battery /power supply?
Chet
PS
1000 turns plus!!!
OUCH!!
It is much brighter inside the coil?
Thanks Grandma
Mk1
@ramset
It means basically that any type of circuit using a toroid capable of coupling with the outer core will run of the main , a low voltage circuit could run in closed circuit.
The circuit could be a low voltage joule thief charging a cap to feed the source .
So the circuit placed in the center either runs for free , or lower amps needed , or be used to recharged source.
I have monitored over 20 volts out of the coil.
Mark
ramset
Mark
Have you seen this behavior before with that little beauty .[extra fine coil
can't believe 1000 turns[I do ]]
Chet
Thanks Grandma
Mk1
Quote from: ramset on January 22, 2010, 10:48:13 PM
Mark
Chet
I tough about using it yesterday , to see if i could some how learn about the Gate new coil symmetry , so it is still pretty new , the hotest spot is in the middle , edge top and bottom , and the edges .
SO over all a nice tool , and a fun toy.
oscar
Hi Mk1,
thanks for your video.
I am working with coils which are wound in a similar way as the one in your video. I call them 'vortex coils' others call them '360° Rodin coils'. I am powering the primary/ies with a square wave generator.
http://www.elv.de/output/controller.aspx?cid=74&detail=10&detail2=6325&flv=1&bereich=&marke=
I presume that in your video you power your primary with a resonant oscillator. Can you point me to a circuit diagram of the oscillator you use?
To clarify: I don't want to power the 'primary vortex coil' from a joule thief. I want to power it straight from an oscillator. Is this what you have done in the video? If so, please point me to a circuit diagram.
note: I am not an electronics expert (in spite of having bought a scope a while ago).
The transmission was a '53 (Johnny Cash)
