Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
EMdevices
The type of coupling Mark uses, if I understand his coils correctly, is not the traditional magnetic coupling/induction.  Instead, this is better understood by looking at the magnetic vector potential fields, denoted as 'A' in most literature.
This A potential field around a toroid resembles the magnetic field around a loop, where the loop is the toroid.  Just another way of looking at EM fields.
EM
Mk1
@oscar
Sorry i am still using the jt for now , but soon will start testing mosfet , maybe on a small one at first 2n7000.
Some more testing do , with a small version of the gate coil.
http://www.youtube.com/user/abramrk1#p/a/u/0/OyiY-N1Ha5A
EM , A field sounds about right.
Mark
ramset
Mark
Thanks for the movie!
Seems like you enjoy playing in those fields :]
Its is good to Know you have j t experience.
Seems like a good baseline to measure progress.
Looking forward to your other findings
thanks for sharing
Chet
Thanks Grandma
Mk1
@all
Some of my friend started replicating , pvc pipe seems to not work at 1.5 volts. And to me this is a no go. Not good enough at 1.5 is still not good enough at 9v...
I would also not use it on any agent gates replication.
Cardboard tube , are great and light , most of them you get for free ...
I have posted more details in the jule thief tread. if you can ignore IST.
Magluvin
Mk1  Would you say that having the inner primary and the outer primary, both on the outside of a pvc tube using pins around the top and bottom, should be ok then?  Or do you think the plastic itself is causing an issue?
This was a question of mine all along. From what you are stating, the inner primary is separated from the outer by the thickness of the pvc tube more than a cardboard tube. So maybe there is an even greater advantage by eliminating that thin space for the cardboard tube, and having the primaries wrapped just to the outside of a pvc tube.
Maybe  =]
Mags
