Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
bullsnbears1
Sorry O.T. but does anyone know why images on posts cover up the text for me on this site? Again sorry for the O.T.
Thaelin
   I get the same problem on some posts. Pics cover up the messages so cant read.
Stephan needs to address this problem.
thay
stprue
@MK1
So I got around to making a coil this weekend.  It is thrown together with salvaged wire. This is different because I'm using the biggo ferrite cores.  The secondary's (12 turns=6X2) are underneath the primaries because of other tests I have been working on with inductive coupling. I have hooked it up JT style and at one point was getting about 13v out of it.  Now I get 2.3 or 2.5vac.  Oh I forgot to mention that the only place I'm getting voltage is off the the same Primaries that the BC are connected to.  The LED will only light one way so if I turn it around and hook it up to the same wires it will not light.  It also humms like a typical JT.   Anyway I though I would share this...well...failure.
Mk1
@stprue
You really should try paper tube , this coil is something different the the regular transformer .
Keep the good work !
Mark
Mk1
@stprue
You really should try paper tube , this coil is something different then the regular transformer .
Mark
