THE "WMM" NPN PNP ALL COIL TUNEING TOOL! {THE MAGIC MAKER}
Started by innovation_station, January 05, 2010, 06:20:00 PM
MrMag
I guess you can't get more of a matched pair of transistors then those. Quite the heatsink on them too. Can you find specs on them? There is a thread where some people are using a push pull type of circuit on the jt that uses a lot less mA. I wonder how these would work? Maybe not too good at low frequency but definitely worth a try.
innovation_station
Quote from: MrMag on January 09, 2010, 12:38:24 AM
yes i have reserched them ...   they are best suited for ag and verry high freq..
with aircore coil  with the switch it on the output...   and allow the colapse to repell gravity ... air core rotatonial quaditure ...  ac ...   24 coils ....
i have 30 boards .. now ..  42 " circles ...  this is MY HOVER BOARD!
they are stable to 1ghz...  o harmonic distortation ...
depends some are lower rated freq like 850mhz ...  i probally have 1000 of them i never counted them ...  and i have a hole skid of rf amps 1ghz to take apart yet ...  they are full of them ...  push and pull ...
innovation_station
im happy we have ironed out this mess ...
i will now get back to work ...  i will mount the super caps to a board and draw up a circuit digram of what my layout is ... to charge batteries ...
i found cell foners to be well suited for the job ... small and light weight ...
altho my gel DOES NOT DROP IN VOLTAGE ... even after 8 hours of rest ...
this is a real constant charge ..  and the battery takes it quite well!
i was verry surprized how well it accepted the charge ...
w
i have roughly 500 coils i can hook up to the MM  already wound!  in every imaginable configuration!
innovation_station
got the super cap board made ...
works as designed ...  basic ...
now i did take meter readings the device on and off b4 and after diode from cap
device turned off ...  voltage of caps both side of diode ...
device turned on ...  b4 diode voltage of caps after diode ...  23 vdc!
ist!
innovation_station
the WMM has feed back employed constant from BASE TO UN RECTIFIED EMMITTOR [ yellow tap point]
on MY MAGIC MAKER  ..  i will expairment to FIND THE BEST DIODE TO SUITE THE USE ...
for feed back currently im useing a crystal diode ...  it works ok  i will replace it with a better one ...
WITH OUT FEED BACK ...  YOUR FIGHTING A LOOSEING BATTLE WITH THE WMM...
feedback reduses use of power BIG TIME ...... ; )  on the input of device ...
i have many pictures online showing the diode  from a long time ago ...
i have built ...  many units that use this diode ...
w
