THE "WMM" NPN PNP ALL COIL TUNEING TOOL! {THE MAGIC MAKER}
Started by innovation_station, January 05, 2010, 06:20:00 PM
innovation_station
here are a few pics my 2 5.5v 1f super caps hooked up + - + -
for a total of 11vdc 1f  i think ...  not sure how that works when you add caps ...
first pic the unit hooked up ...
second pic the cap board ...
I WILL USE SUPER CAPS OR BATCAPS AS PER MY DESIGNS...  ;)
FOR THE SMALLER UNITS I AM LOOKING INTO SMALL BOOST CAPS  FOR MY PORTABLE POWER SUPPLYS...  THAT ARE SOLAR IN NATURE ...  : )  AND MANY OF MY DESIGNS HAVE INVERTORS  BUILT IN ...   i can not afford to build all i have drawen up and shared ...  i have litterly 3000 ideas or more on this site
and i have INFINITY X 2  MORE TO COME!
the last pic is the rectified BASE FLYBACK! FED TO EMMITTER WITH PULSE ...
I do know and understand my stuff verry well !
this is ELECTRICAL FEED BACK ....  i have about 20 other ways i can feed back easly!
most  are shared public   many moons ago ...  i just never made em bright red !  ; )
be it electrical   magnetic  whatever ....  heck i think i was the FIRST TO FIGURE OUT FEEDBACK  PUBLIC...
AND I WELL UNDERSTOOD THIS SOME TIME B4 I SHARED IT  YEARS AGO NOW!
probally  when i proved the calculation of horse power incorrect!   ; )
why me ?!?!?!?!
ist!
i might aswell add this i solved many things i have drawings that go back many years of mechanical hovver or ufo designs ...  most mechanical devices...
i still can not see why they wont work EVEN WITH ALL THE NEWER THINGS I HAVE LEARNED...
it seams they are verry possible many ways ...
i have joe cell drawings and my implosion turbine modle design ufo unit ...
but we wont go there yet! nor the tesla turbine pump and style unit ...
i yi yi
innovation_station
Quote from: innovation_station on January 09, 2010, 11:37:51 AM
got the super cap board made ...
works as designed ...  basic ...
now i did take meter readings the device on and off b4 and after diode from cap
device turned off ...  voltage of caps both side of diode ...
device turned on ...  b4 diode voltage of caps after diode ...  23 vdc!
ist!
aswell today i will ADD A SECOND CAP I CAN SHORT AT WILL : )     lol
if you knew the importance i the words i speek!   boy0boy!  ; )
and i aint talking ...  device talk here .....  lol   THAT WAS A RA HA ! hehehe
sheesh   im totally nuts but its fun ...  or it can be!  : )
anyhow i will split tap points at the diode ....
i shall explain ... !
peace!
W
innovation_station
NOW it gets nuts....
i split the recharg from the super caps ....  chargeing my 12vdc battery ...  found the crystal diode im useing to WORK BEST!  any how  ...  i was able to charge supers battery and another cap all at diffrent voltages /...  with out effecting the operation of the WMM
so
i then used the feed from the y where i taped the battery and the second cap then i common grounded the BASE  LOL   B4 THE DIODE FOR FLEEDBACK... lol  and i have my
supers OVERCHARGE FAST ....  MY BATTERY RECHARGE INCREASES ...  AND MY BIG 350VDC 25000UF CAP CHARGES TO 25vdc  no problem and climbs ....
while doing all the other things ...
like i said  getting NUTS
W
i can then siphon off my big secondary cap that causes my device to ACCELERATE ....  to a smaller cap and pulse at 25vdc ...  constant...  AS LONG AS I DO NOT TAKE TOOO MUCH AT ONCE ...
and even if i run a motor off it ...  the caps will refill still fast when i stop running the motor ...  but slowly depleate while the load is running ...
it seams i MUST PULSE FROM THE SECONDARY CAPS .... OR MY SUPPERS OVER CHARGE ...
HUMMMMM
innovation_station
yes another odd effect!
as i increased the second cap ...
when i turn it off  it looks like the diodes run backward and feed back - 3v  to the source battery .. with out the use of the tickel unit...
im trying to flip it around and use it to charge a low volt cap to feed back to the battery ...
it is strange ...
ist
i have found if i flip my battery to turn off my device with the switch on ....  IT RECHARGES .... with the - 3v...  : )  lol
innovation_station
YEP JUST ANOTHER WILD SUN DAY!
lol
i made a video ....
watch it ...
im sick of typeing ..
W
i have to re make it it is too long .....  lol
