Solid State Orbo System
0c
@Groundloop,
Something like that MEG coil ...
Take a coil of heavy garden wire (soft iron) and wind copper magnet wire around it into a toroid. The iron wire acts as both a permeable core and generator coil as the field oscillates.
Just a wacky thought.
hartiberlin
Hi Alex, did you ever use
smaller magnets or bigger airgaps between magnet and core with this Metglas core ?
It would be probably fully in saturation and
it would really be hard to switch the flux from
one leg to the other with low input power, so I guess
you killed the right effects with this very strong magnets
being on a totally false BH curve working point...
You really need to measure the flux density in the airgap
with a Gauss meter
so you know what BH working point you are on...
Regards, Stefan.
Groundloop
Oc,
I have not tried garden wire. I will let the Tom Bearden MEG rest for now.
I spent almost three months testing that unit back in 2007. I did build
the MEG from patent information but did not get it to work. Maybe I will
try more testing on the MEG one day but not right now. I have had more success
with the toroid shielding and I think that can be implemented into this MEG.
Alex.
Groundloop
Stefan,
Something to try out, yes. I did not try lesser strength magnets.
But you are probably right that we must get the correct field strength
to get this to work. So this is on top of my "to do" list the next time I
take out the MEG for a spin.
My main focus right now is to build the double field solid state as described
on page 1 in this thread.
Alex.
Bruce_TPU
Hi Alex,
This post here:  http://www.overunity.com/index.php?topic=8411.msg222284#msg222284   we must think through how to use a high permeability, high induction coil for our "magnetic shielding" switch.  This should lower our input power dramatically!
We would need to make sure the strength of the magnetic flux is just < than what is needed to saturate the core.  Add a touch of current to make the difference and boom, our "switch" is on and then off and one cycle gives us juice in our generator output coil.  Maximize the output coil by using Brooks coils and increase the "frequency" to the MAX and we should be back off to the races!!   ;D
You would need a mininum switching circuit.  Just enough current to make the saturation difference between the core and the magnetic fields on both sides of it.  We must be much more "technical", about this.  If we are, I can see us with a greater output.
Cheers,
Bruce
