Solid State Orbo System
Groundloop
@lumen,
There is not much I can do with that. When you put two cores together
then the middle part will be twice as thick as the rest of the core. See
attached image.
Alex.
0c
Quote from: Groundloop on January 19, 2010, 01:20:30 PM
@lumen,
attached image.
Alex.
You could try something like an "H-Core". I have no idea where to find one, but something like that might fill your need. See figure 2 on page 12:
http://books.google.com/books?id=SMASAAAAYAAJ&pg=PA162&lpg=PA162&dq=transformer+%22h+core%22&source=bl&ots=Uozy_6nhkn&sig=SImjM81mMbxNJNgcCl1bI87EwY8&hl=en&ei=I_9VS8sjitK2A7Or_LsN&sa=X&oi=book_result&ct=result&resnum=55&ved=0CNMBEOgBMDY#v=onepage&q=transformer%20%22h%20core%22&f=false
gotoluc
Hi everyone,
I have an update video of the Flynn Parallel path device since my first test was not well done. You will see the results are even better in this test 2 video then the previous one.
Link to video: http://www.youtube.com/watch?v=i91F5VQD4JM
Luc
Groundloop
Hi Luc,
Great test.
Attached is maybe something to test in your setup?
[Edit] Got the magnets wrong, corrected that.
Alex.
Bruce_TPU
Quote from: synchro1 on January 19, 2010, 10:51:11 AM
@Bruce,
Everything appears to be correct except that I envisioned the output coil on the larger of the two stators for the 10 times the flux. I see now perhaps that both single armature's might be wound with output coil wraps, and your version might work just as well as you presented it. The Backdraft concept of Paul Noel's, Backdraft closes a large door I imagine, would allow for an ever increasing progression of interlocking parallel path stators and armatures, triggered by one tiny one at the beginning of the chain. The performance of the toroid coils might be surpassed by Ossie Calanan's metal hoop which I imagine might just fit tightly around the middle magnet. Good luck! I look forward to your youtube video with great enthusiasm.
Snip
Hi Synchro,
How about this?  Is this what you were picturing?  Of course, I will be able to try the coil in different locations, but I would like to succeed the first time out...  ;)
Cheers,
Bruce
