Solid State Orbo System
Magluvin
Wow is the werd.    I read it and the cap for resonance makes sense. Were there some tpu's that used magnets that didnt require an input?
Mags
lumen
I believe this cuts all the additional routing of the fields and possibly improves efficiency.
The outer windings are the output and the toroidal windings control the field.
When the toroidal windings are off, the core becomes the field conductor for the output windings.
Bruce_TPU
Quote from: Magluvin on January 19, 2010, 10:11:36 PM
Mags
I too had suggested on Alex's prior test to turn the output coil into a resonant tank.  This inventor claimed that it was the only real way to pull power off of it.
Cheers,
Bruce
Magluvin
Thats funny lumen, I got the same or similar idea except for the coil arrangement. Actually I have the coil next to me, Ill make a pic later. Imagine a coil 1.5 in. long by 3/4 in. width and 3/8 in. air core. Now I am going to wrap this coil as if it were an elongated toroid with some fine wire for low current. This may not require a magnetic core to make the original coil disappear and reappear.  i have som 3/4 in x 3/8 n52 mags that make this a tidy experiment. Just the wrapping of the toroidal coil will be many wraps. I am going to make 3 separate windings for options.
We will see. So the idea is to use the least input to block and release so we can get more in return from output.
Ya know, latly I have been seeing electrons moving slowly. Just visualizing, not that I actually see them. silly
But in a circuit of very high resistance and very low voltage, I visualize them kinda just a bit jumbly, shoving and bouncing as a new one enters the circuit from the source, one exits, but its not the electrons that are moving at light speed, its the pressure wave in the matrix. I wonder if there is a resonance for electrons, a freq that we just vibrate them without pushing them into a resistive position, thus zero transmission resistance. Im sure at 60 or 50 hz there is some real electron movement.
Magluvin
Before I run off to wrap this, I just had some thoughts of why this is going to work well. Imagine the toroidal coil off and the 2 mags passing through the gen coil. Now imagine the twisting turmoil in the gen coil while the toroid is on. So just the change of field in the gen coil should generate something.  Just goin left, before I go right.  I may try a thin core in the middle, the toroid should still foul it up. Trying the simple first.
Mags
