Solid State Orbo System
gyulasun
Quote from: Bruce_TPU on January 19, 2010, 09:42:34 PM
Hey guys!
A friend of mine sent me to this post, over two years old...and WOW!
I will quote it here and repost the pictures....  Sound and look familiar?   ;D
Hi Bruce and All,
It is good you quoted the text on the Bulgarian MEG, here are some more links on nice animations and / or further ideas on the same, from that thread for those who may not be aware of them
http://www.overunity.com/index.php?topic=4300.msg134122#msg134122
http://www.overunity.com/index.php?topic=4300.150
Needless to say, all setups shown are based on soft iron core saturation, caused by the input current.
rgds, Gyula
Magluvin
Ok  Here is a vid of my version of SS eorbo.   My next go at it will be with more toroid turns to increase the effect and possibly efficency.
http://www.youtube.com/watch?v=9Ljx1py-BUs
Magscave
Bruce_TPU
Quote from: synchro1 on January 20, 2010, 12:41:55 PM
@Bruce,
          Look at the way you have the armature pictured in the smaller stator. It is to the outside with an airgap, large enough to cover the end thickness of the stator arms. You pictured the larger stator with the armature enclosed inside the stator arms. It needs to be lengthened and brought to the outside with an airgap so it resembles the the armature on the smaller one. The size position and air gap of armature on the large stator needs to be proportionally identical to the way you have the small one pictured. Now, all that's left is to wind the output coil on the larger armature, the way you pictured it wound on the smaller one in your earlier versions.
snip
Okay, this should finally be it... LOL  I am going to build this.  My cores have come in and I am soon to order my iron oxide powder.  I am going to make forms, lay it out and mold my pieces.
I am thinking of mixing in some nanoparticles just for fun... ;D  I think it would help.  I am looking VERY forward to this build!
Cheers,
Bruce
Magluvin
One more vid. Down to 2 AA bats  2.4v and using a string of 1/4 x 1/8 neos inside the core to replace the large mags.
http://www.youtube.com/watch?v=JYXU_ClBrIA
Im tired, goin to sleep
Mags cave
gotoluc
Quote from: Magluvin on January 20, 2010, 05:54:44 PM
Magscave
Hi Magscave, I must say that video looks impressive.
If you hook up your Ammeter between your battery feed to the coil does the amp draw change when you add the magnets and the output voltage shoots up?
Thanks for sharing
Luc
