Solid State Orbo System
synchro1
@Bruce
          Congratulations, perfecto! I have an acronym for this model: The (FOMEGA). Flynn Orbo Motionless Electric Generating Amplifier. Good luck.
Magluvin
Luc
This setup seems to drain the batteries faster than my pulse motors. I am assuming that it is due to too few windings on the toroidal windings at 3 ohms. I would like to see about 15 to 20 ohms there. I got tired of the wire tangling or there would have been more here. Wrapping a toroid requires a specific amount of wire to be cut beforehand. A time consuming wrap.
The pickup coil is wrapped to the inner core first, 3 layers of 50 turns each 26 ga. then the red toroidal coil is wrapped over that.
Check out this vid below. At 3:14 sec in   it seems to show Agentgates idea. Then just after that, 3:50 , something very close to my lil Orbonbon setup.  The pickup coil wrapped on the core in this vid is closer to what I want and also the toroidal wrapping is more to what I would like also, more turns virtually covering the toroid.
it seems like all these ideas have been there all along.
http://www.youtube.com/watch?v=neiOQgYw_Qc
Will have a bigger better Orbonbon this weekend. Maybe an Orbaseball.  =]
Mags
Magluvin
I played with the Orbonbon a bit.
The big mags were too much, but they also have their opposite ends exposed. If they had a path to the other side there may be a difference.
The 1/4 x 1/8 in series does very well inside the inner coil. The number of them to get the most is the number that gets them just below flush on each end. I put some biasing mags on the sides of the outer core and there is some that help a lot. But just with the 1/4 in strip, I get 150 - 160v out now. I put an led on the green coil before the bridge, and it was toast. I saw literal lightning in this one. So I shut it down, grabbed my cam and did a very short vid of the lightning and the new output record for the Orbonbon. This weekend I will re wrap for more output and more invisibility turns.  I really want to get less input and more output.
From here it seems like an easy direction to follow.
http://www.youtube.com/watch?v=B5LFSsdUCTE
Does anyone have an SS orbo going yet?
Mags
gravityblock
Quote from: Bruce_TPU on January 19, 2010, 09:42:34 PM
Hey guys!
A friend of mine sent me to this post, over two years old...and WOW!
I will quote it here and repost the pictures....  Sound and look familiar?   ;D
Quote from: LoganBaker on March 17, 2008, 04:32:56 PM
    2. He also claims that capacitor is absolutely necessary to be
    connected to the output coil to obtain resonance. It also makes TB's
    patent claims about zero phase difference between output coil voltage
    and current somewhat suspicious.
    Thanks!
    Regards,
    Logan
After looking at the Pancharatnam-Berry phase, http://en.wikipedia.org/wiki/Berry_phase , and the Aharonov-Bohm effect, http://en.wikipedia.org/wiki/Aharonov-Bohm_effect , TB's claims on zero phase difference doesn't look suspicious at all.
It has to do with the uncurled A potential outside the core, due to the localized B field inside the core, pulling extra energy into the core from space/time itself.  Steorn, TB, and the Adams motor appear to all be based on pulling this extra energy from space/time into the core based on the same effect.  There are so many similarities between all of these devices and they all have the same common theory.
Wheeler clearly pointed out that mass and space continually interact. Quoting Wheeler: "Space acts on matter, telling it how to move. In turn, matter reacts back on space, telling it how to curve."
http://www.cheniere.org/techpapers/On%20the%20Aharonov-Bohm%20Effect1.doc
http://peswiki.com/index.php/Site:LRP:The_Suppression_of_the_M.E.G._by_General_Electric
GB
Magluvin
Ok  I just posted a vid of Orbonbon current draw. And an example of output. Next is to add to the toroid to lower input and increase the invisibility effect and hope for more output.
Next is  Orbagel!  Err SausageMcOrbo!
http://www.youtube.com/watch?v=2HAjkSNiXZ8
Magscave
