Solid State Orbo System
rave154
MAG,
great work so far !!!
beautifully neat looking breadboard btw, my breadboard circuits look like a plate of spaghetti thats been chucked onto the floor and re-arranged by a spider thats tripping on acid ! ( yes, they are THAT bad )
as a way of testing efficiency ( and of course wether or not youre approaching OU )... could you try the following...
charge up a large'ish FARAD cap to say youre standard 5V...use this as your input supply....
on the output use another large ( preferably larger ) cap... run the circuit until the input cap is empty... you will know how many joules you have used on the input from
E = 1/2 x C x (V^2)
now simply measure voltage on output cap  and again use the same formula to give you joules of energy on the output. ( you may need to use quite a large cap on the output so that it doesnt fill up completely before the input cap is all used up )
cant wait to see what the results are.
interesting that the caps on both input and out output circuitry have such a beneficial effect, i tend to aggre with you that are adding "bounce"..and each time it bounces youre output coil is picking up the changes in flux.
p.s re:- casting cores, 1 more advantage to casting your own is that it enables you to place either the input coil or the output coil (or both )... actually INSIDE the core...as opposed to simply "around" the core .....this 'might' allow more flux-change absorbation in the windings? not to mention of course that doing it this way the outside of your inner toroid would be a nice standard size & shape as opposed to being bumpy & irregular by having wire wrapped around it ( the wires would now be tucked away inside the core itself ). Obviously if you were going to do this, the coils would have to be pre-wound beforehand..then placed into the space in the mould and then the magnetite goop poured into the space.
Oh, 1 last thing, you should be able to get black magnetite ( FE 304 ) from art shops ( possibly craft shops too ), they use it as a pigment, should work out somewhere along the lines of $7-8 per KG roughly speaking.
Groundloop
@Magluvin,
Great work but please try to post a little smaller images.
(I did scale you images down 50%).
Regards,
Groundloop.
Magluvin
Sorry about that. Im not sure why it came out like that. But this is much better.=]
Thanks
Mags
synchro1
Ossie Callanan demonstrated his coil wrapped bailing wire strand toroid coil and simple electric drill winding techniques on three new youtube videos. Imagine a bifilar pancake coil wrapped this way. When the wraps reach the end, they just need to go back the other way and cover the first winding. Now, if the wire and copper coils are twisted into a spiral, both ends of the copper coils come out the same side of the pancake. This would make a great flux modulator sandwiched between two tube magnets, or in the middle of a stack of disk Neos. Also, one on each side of the center magnet in a five cube Hallbach array would switch the unidirectional field on and off. allowing for a high torque attraction motor, or endless MEG configurations. This pancake coil would lay flat, and permit maximum surface area to contact, unlike the hole through the toroid, which provides the magnets a way to combine strength. This seems like an ideal flux trigger for Bruce's FOMEGA! Tesla patented just such a bifilar pancake coil. I could never figure out what kind of application he had intended for it. Perhaps it was the same.
Bruce_TPU
Well some small progres on SS orbo.  I have purchased Elmer's Fiberglass resin.  It is with me.
Next I ordered online, 10 lbs. of FINE Black Iron Oxide powder.
Next, I ordered online, 1 lb of.....are you ready for my secret ingredient?  LOL
ACTIVATED CHARCOAL Powder!  I will mix a small bit of this with my iron oxide, and this get's mixed with my resin.  I will then use this to build my "bars" of super flux increasing nano particles.  or SFINPO for short.  These will then be used to build the FOMEGA as posted.  I already have some tremendous coils ready as pick ups.  I will post vids of my build of course.   ;)
Cheers,
Bruce
http://www.energyfreedomreport.com
