Solid State Orbo System
0 Members and 31 Guests are viewing this topic.
Bruce_TPU
Quote from: Jimboot on February 07, 2010, 02:23:15 AM
@bruce_TPU I wound my original Orbo toroids with 0.5mm 24bs. http://jaycar.com.au/productResults.asp?FORM=KEYWORD Tried posting a pic but it was unreadable. Also I used Ossie's method of winding on 3 strands at a time to a shuttle device. I simply used a hard flexible piece of plastic with a V cut in each end to first wind the wire onto then did about 3 layers (ferrite cores) & wired them in series. I used EXACTLY the same toroids as Ossie. http://jaycar.com.au/productView.asp?ID=LO1234&CATID=33&form=CAT&SUBCATID=882
Hi Jimboot,
So your .5mm is indeed about 24 awg.  How many turns total, or if you don't know that, what was the total length? (of all wires in series total)  Thanks!!
I will know shortly if my newly wrapped magamp works, and if not, I am ordering Ossies and your core from Jaycar.  I just need to know about how much wire, or turns.
Quote from: Magluvin on February 07, 2010, 03:06:38 PM
Hey Bruce
In earlier posts, I reported that the coil interaction alone, without mags, were pretty low. With just the inner bead, not inside the outer bead, the voltage on the secondary was like 2v, and when inside the outer beads, it was up to 3v but not much current. So the magnets fields I believe are doing as I figured, switching beads as the inner bead is doing a disappearing and reappearing act. =]
mags
Hi Mags,
I certainly believe you, it simply would appear from looking at your toroid, and know the hell I have had getting any of mine to properly saturate that you have so few turns.  You might consider rewinding another, with a shorted layer as per LarryC.  Then your pick up coil, and then a lot of turns.  And then try JLN Labs test to make sure a magnet wont stick to the outside when it is switched on.  I just think that it will help your results mightily!   ;)
Cheers,
Bruce
Magluvin
Hey Bruce
Wouldnt the shorted coil absorb some of the field that Im trying to get my pickup to absorb?
Maybe I misunderstand what the shorted coil is for. If you think it will enhance the pickup, I will try it.
At this time with the cores that I have, I am limited to space on the inner bead for more windings than are there now. Each of the beads in the pic you have noted have the same wire size for the pickup and the toroid. The one on the left is maxed out for size. Do you think if I used smaller wire for the pickup, that I would still get good current output? I have wound quite a few to get to this point.  =]
Mags
Magluvin
Syncro
Have you seen Tinselkoala's YT vid on the Orbette where he applies biasing magnets to the toroids to get the rotor to go faster?
Mags
Magluvin
Bruce
Also I am running 5v to the toroid coil, which makes a difference from 1.5v.  Maybe the Orbo could do better with higher volts also.   =]
Mags
synchro1
Magluvin.
Thank you for referring me to Tinselkoala's latest Biased Magnets Orbette Video number 51. Looks like TK has really outdone himself in this one. His results are truly astonishing! RPMs increase about 50% while input power drops. Excellent proof of concept demo for that idea.
Bruce,
What kind of material do you plan to use to cast your stator in? Wax or green sand?
