Solid State Orbo System
Magluvin
Syncro
It may be a good thing to bias the stators here. I dont have an orbo setup at the moment, but if you try, check to see if the input current changes with or without. I have in the past posted that if you have a small dc motor and add neos to the ouside casing, the motor runs faster, but at the expense of input current rise. But the orbo function may not be the same and hopefully the input remains the same.
Mags
Bruce_TPU
Quote from: synchro1 on February 08, 2010, 12:39:56 PM
Magluvin.
Thank you for referring me to Tinselkoala's latest Biased Magnets Orbette Video number 51. Looks like TK has really outdone himself in this one. His results are truly astonishing! RPMs increase about 50% while input power drops. Excellent proof of concept demo for that idea.
Bruce,
What kind of material do you plan to use to cast your stator in? Wax or green sand?
Hi Synchro,
Actually neither... :-)  Wood form, using 1/4 round, for mold, rubbed down in vaseline.  It will work just fine.  I just need my toroid to saturate.  Added more winds, but still not enough.... So, I keep winding.  I may have to wind until the hole is filled.  But all magnets are ordered.  But instead of building my forms, each evening I wind my toroid and test and wind some more.
Perhaps I need more current?  I have about 2 amps coming in off of the bread board, at 5 volts.
Cheers,
Bruce
http://energyfreedomreport.com
Magluvin
Your right Bruce. I am not saturating the core. Hmmm.  Its funny.  I wonder how the toroid in the graphics pics you posted can possibly work with such few turns, or is it just a simple representation to show the basic idea.
Well what I will have to do is go through the cores I have and guesstimate enough room for mags while expecting some thickness of the windings. I am going to have to rethink my order on the new cores. Maybe I can make them work somehow. And if I can get good sat. maybe the pickup outside will work better.
Man, if I am getting output as good as I am without saturation, then with it, I should be getting some huge increase.
I dont want to get too excited yet, but it does seem so. Ive Been disappointed many times before, cant hurt much.  Im thinking a few separate windings that tap out, using thin wire, and it will give me the option of series or parallel, or trying singles. Ive wound many and I just want to make this one variable in hopes of finding the goods in a single shot.
Thanks for bringing this to light Bruce. Im not always a fast learner. =] But Ive got a solid foundation going now.
Mags
Magluvin
Ok  I worked all night, at work, and was thinking and thinking, and now im home and Im gunna rap, err wrap umm windum up and sew me a wet toroid, err saturated.  Im all silly from no sleep an im not goin to bed yet.
I got me a few more toroid cores from some pc power supplies so I have a few more choices for a victim.
Man I hope this works. Maybe Ill take a few more punches. Bip bap.
Will report in a few.
Mags  Orbominator   Orbonbon on Toroids   =]
Magluvin
Half way done. The pickup coil is only 18 turns of 2 layers of 9 , 22ga.  The toroid winding is 30ga and this is just the first to tap out. 1 more layer of the same and she will just fit the outer core I have chosen.
The magnet will be a 1/2 x 3/8 N52. This is tedious work. Having 2 separate toroid windings allows a little flexibility to connect series or parallel to see what works best.
Mags
