Solid State Orbo System
rave154
Thanks mag, that helps put it all into perspestive some.
Magluvin
While I was working, I had some thoughts. I have a few more computer cords around to get a couple more beads from. I dont want to take the first 2 working ones apart to keep as a reference.
What I was thinking is, these 2 cannot be the best there can be, not off the whim. So Im going to combine what I know about these 2 and try some different configs with the windings and compare. I dont have anything down to a science so try and test is the best I can do till I have some variations to go by. 2 is not enough. But going with what works for now is the best bet.
If I have 4 different ones, I should be able to get a handle on which direction to go from there to get closer to what is better.
Mags
Magluvin
Some more thoughts.
In the beginning, when I had seen the flux gate Bruce had posted with the toroid on the left and the pickup on the right with a gap, I thought, wow, what a great idea. But now i have to question.
The amount of energy it takes to get the toroid to saturate, is it equal to or more than the energy produced by gating the flux of a mag?
The only way to find out is to use a magnet that, while conducting flux through the toroid, is able to saturate the toroid core also. If it is any weaker, we are failing to reach full potential. If it is stronger, will the flux from the magnet overcome the toroids field we are trying to saturate the core with?
My Orbon is just a simple idea to try and produce the generating effect of flux switching. Nothing calculated, just try to fit what I got and see what haps.
Can it be that the end result can only ever be under 100% efficiency, like many other devices?
All in all, Im happy that the idea of it works at all. And I cannot discount it yet from the little that I have done.
A circuit that I messed with last week, a switching ps type, pulsing a Big coil and the bemf is captured off the coil, I had made a vid of the output burning a light bulb. Vid below, and please read the info there on my errors. The errors were why I had not posted it, but now I am and will do a new vid here soon with corrections and findings
I am going to revisit, as Bruce would say, this setup. I see some interesting things here that I need to find out what was going on with the in and out connecting. But in the setup, when I put the 5ohm res on the output, it was very close to the total watts of what the 5v 1a ps could put out. Under 100% but pretty close.  But I need to find out why only 30v without the in/out connection and 60v with.
http://www.youtube.com/watch?v=B5uJL--N_qo
Mags
Bruce_TPU
Hello ALL,
I have spent the evening working on my forms for my homemade nanoparticle iron oxide flux multiplier beams... LOL  (See pictures below)  I am not going to mold them up until Saturday when I have some real time.  I am going to video the process as well.
The virus is off of my computer after much work, but it damaged some of my registry I think.
@ Mags
I wound my coil with the taps, but it needs far more winds to be added.  I have a pulser being made that I will be using to experiment with our SS orbo and also with the orboton.
I did fool with it a bit, using my rotor and relay as switch.  The magnets sure hummed a pretty note, but it needs more winds and a real pulser.
Lastly I would caution you and others experimenting with this, to only use an analog meter for measuring voltage, or scope.  Digital multimeters are pretty much useless for this type of research.
Cheers,
Bruce
http://energyfreedomreport.com
Magluvin
