Solid State Orbo System
synchro1
Quote from: haithar on February 19, 2010, 06:34:55 AM
Naudins experiments on a solid state system have no significance unless data on input parameters (current, voltage, duty cycle) are provided, same for the output.
What's special about a system that transforms energy between inductance's, even if it only works with magnets? It's not interesting until power output exceeds or is equal to power input.
JLN is doing much more then transferring power between inductances. He is generating power with a magnetic field flip between the outside and inside of the Nanoperm toroid. This would require the rotation of a bar magnet past the output coil to accomplish normally. The startling difference in JLN's 2SGen is that there is no Lenz drag nor loss to resistance.
haithar
Quote from: synchro1 on February 20, 2010, 03:08:46 PM
How would you know that? Even in usual transformers the magnetic core is saturated and then polarized in the other direction - going through a hysteresis loop. Power is not generated but transferred. And isn't induction the very basis of inductive coupling? Lenzs law gives only information about the direction of the induced voltages/currents.
The only difference to a usual transformer is the magnet. Again, to make this interesting he needs to deliver data. I hope he does not stop after a qualitative test like on his Orbo motor but also does quantitative tests.
Groundloop
Bruce_TPU
Hello ALL,
Okay, here it the much awaited "how-to" video for my Nanoparticle Flux Bars...LOL  I worked hard on this vid, so please rate it if you like it.
http://www.youtube.com/watch?v=hnY1Zbi7sgM
Cheers,
Bruce
http://www.energyfreedomreport.com
Mk1
@all
Two idea , use a cylinder neo around the pickup coil , one with with one polarity one the inside the other on the outside.
Second idea would be to use a cream cone shape magnet , the gauss is concentrated at the tip , i think this is what magnacoster is doing.
I would use soft iron for the core for the pickup coil , I may be possible to salvage some from electromagnet , the quality of the iron is important.
Also the ferrite toroid should be used on its side so the pickup core could be under the magnetic influence at both ends.
I wonder if a pot core would work ...
Anyway keep the good work everyone.
Mark
