Solid State Orbo System
stprue
It seems that there is definetly something special happening here.  Very good video.
Bruce_TPU
Hello All,
Okay, this morning I feel like I have made some real progress "optimizing."  I added a magnet on the other side of the toroid, and a small magnet inside of the toroid and the voltage went up.  I then noticed that if I brought my first pick up coil close to the magnet, voltage went up, but if I moved all three close to the magnet that voltage went down.
I then realized that the magnetic fields in my pick up coils were opposing one another and when close, having an adverse affect...so.o.o ...I turned the last two pick up coils around...and WOW... what a difference!  I am now up to 1.2 volts from the .045 where I started last night.  Slow speed turn of the rotor (my switching for my circuit right now) give me .8 volts.
I built this one based on the plans we worked up, and I must say that the flux is indeed increased by about a multiple of three.  I have some other ideas to try tonight, and it is time for a video, I think.  The Led lights up very well now.  Again, remember, once I can put some real speed to this thing...hehehe!
Cheers,
Bruce
http://www.energyfreedomreport.com
Magluvin
synchro1
Looks like the same thing, except JLN's magnets are are running across the toroid not through the axis. Diametrically magnetized cylinders running through the core would give you the same field alignment, I wonder if they would increase your output? You're definitely out in front, both with the magnets inside the toroid core and now with your BEMF pulse recovery loop.
rave154
MAGS & bruce..
GREAT work so far !!!!!!
