Solid State Orbo System
Bruce_TPU
Good evening ALL,
Well time to "optimize" some more.... ;)  I had all day at work to think things through, and I decided first thing to begin to "remove" pieces and see what is really working, so that I can improve those things.
Well, the first piece I removed (because in my mind it didn't belong there!) was one of the magnets, and in doing so, my output voltage has JUMPED from 1.2 volts to 1.87 volts!  Now, you may not think that a lot but percentage of total, it is huge!  Please remember, this is simply using the hand turned rotor as a switch for my circuit for the time being.  Optimize to the point I can do nothing else mechanically to improve things, and then I will add a "real" adjustable frequency and pulse width to see some real power.  Those who know me, know I am very patient and methodical...
I will Edit this post as the evening warrants:
Cheers,
Bruce
http://www.energyfreedomreport.com
EDIT 1:
*Removed all magnets except for small one in center of toroid.  Output voltage of SSG! was .9 volts
*Placed magnet on the opposite side of toroid, and voltage is now 1.93 volts...please see picture Revised Flux Path 3.
Bruce_TPU
EDIT 2:
I have pulled off the bottom nanoparticle flux bar and the end piece.  Please remember, that I am dealing with experimental bars and they do not behave like normal iron or steel!   ;) ;D  30,000 square feet of surface area just in the one bar!   (mad scientist laugh...hehehe!)
Voltage is now at 2 volts and I have all kinds of ideas now to increase that...
EDIT 3:
I have placed the magnet over the toroid side, and now I am at 2.2 output volts on the SSG1.  Rotor switched!
See Revised Flux Path 5 below.
Edit 4:
I have removed all nanoparticle bars and placed half the toroid with the magnet on the side, inside of the top pick up coil - 3 volts!
EDIT 5:
I am going to continue to work with this tonight, and then buy some steel plating tomorrow and redo my previous "parallel Path" experiments, using the steel.  I will post tonight if I bump the voltage some more...
Bruce_TPU
EDIT 6:
I tried adding more magnets on the other side of the toroid, stronger magnet than what I have, nothing worked...BUT...add one steel bolt..and we are now up to 3.2 volts, and then at a VERY SLOW rotor speed, it stays above 2 volts.  The LED is now VERY bright.
EDIT 7:
I have enclosed a real photo below.  What I have done now is initiated a form of "magnetic feedback".  I took my steel bolt, wrapped it with very fine magnetic wire, I think 32 awg, one layer, and wired it in series with the output of my pick up coils.  So.o.o every time the output pulses around the bolt, it turns it into an electromagnet, which pulses and further creates power inside of my pick up coils.  I am now up to 3.5 Volts and 2.8 to 3 volts at VERY slow rotor speed!
It is interesting, with the addition of the steel bolt, how violently the toroid vibartes inside of the pick up coils.
Bruce_TPU
Hello ALL,
I think I am onto something with this "Magnetic Feedback" that I have initiated.  This is the scenario:  I placed a fourth pick up coil on top of the three, while placing a new LED across the new coils leads.  Spun the rotor, and I am still getting the 3.5 volts on the output LED, but now the LED on the fourth coil lights up dimly.  Remember, it is solo, not wired in series.  While lit, I slowly lifted the coil, and as I did the LED stayed lit until it reached the top of the electromagnet windings over my bolt and then died, even though there was some bolt, unwound still in the center.  I think I will leave this coil out by itself for now, and increase the feedback windings on the bolt.  This should strengthen the pulse of the electromagnet and I should see a bump in voltage and brightness of top coil's LED.
If this works, the next logical step would be to increase the length of the bolt and place the rest of my pick up coils on top with that lengthened bolt through the center, and see what I see!
Cheers,
Bruce
rave154
Nice work so far Bruce,
can i ask, what voltage & amperage are you drawing from the input supply..and.what duty cycle approx?
Thanks,
David. D
