Solid State Orbo System
gyulasun
Quote from: Bruce_TPU on February 24, 2010, 09:43:16 PM
Hello ALL,
Can anyone say...WEIRD..lol.  I just added a blue A, this is the third in series, brightly lit, and NEW output voltage....   8 volts  !!!
@Bruce
Magluvin nicely answered your question and may I add that LEDs are like Zener diodes but they conduct in the forward direction with these forward voltages depending on their color. Under their forward voltage threshold they do not conduct.  So they must have a positive polarity received at their anode wrt their cathode, and this voltage must be a bit higher than the threshold forward voltage, otherwise no light can come out. And in the reverse direction they do not conduct at all, till the reverse voltage reach a so called reverse breakdown voltage, this latter ranging from 7-8V to over 10V or so, LED-type dependent.
If you find the frequency increases as you add more LEDs, then probably the loading effect of the LEDs that they have on your output changes: more LEDs mean decreasing loading current while the output voltage increases. If you try using loading resistors instead of the LEDs, in an increasing value order, like 100 Ohm, 200 Ohm 500 Ohm etc and you also find the frequency changes you may check this.  However, using resistors will mean the load is connected in every moment while in case of the LEDs they conduct in every second half wave of the output waveform only-- (here I assume you do not use a full wave bridge in front of the LEDs) --whenever the peak voltage exceeds the forward voltage of the LED(s), and this is a huge difference in the load.
@Magluvin
To answer your blue LED question, Bruce meant he added a third (a blue) LED in series with the previous two, so the total forward voltage drop (8V) was the sum of the three diodes drop, ok?  By the way, Bruce has a "built-in" resistor in the coil (and can serve for the LED as a limit resistor if you like) because the DC resistance of his coils is 753 Ohms, huge number of turns made from thin wire.
rgds, Gyula
Bruce_TPU
Quote from: gyulasun on February 25, 2010, 09:23:07 AM
@Bruce
@Magluvin
rgds, Gyula
Outstanding explanation Gyula.  Thank you! And thank you also Mags.
@Aaron
I will do this later on.  This morning I broke my unit back down to 1 coil.  I have some weird TPU'ish (new word!) ideas I want to play with this afternoon with the setup and see what I see..
@All
It would seem that the magnet within the center of the toroid accounts for much of the output voltage.  So, what do we do with that knowledge?  I want to wind my brooks as a toroid and then wrap a wrapping around that, with an additional magnet and see what I see.
Cheers,
Bruce
http://www.energyfreedomreport.com
Bruce_TPU
Evening ALL,
Tonight, I have changed my LED's for 10mm White LED, with an intensity of 28,500 mcd.  Forward current is 20mA and Forward supply is 3.5 volts.
I am at 2.5 volts output, using one coil, lighting up (not completely) my new LED.  I have a lot of new ideas to try and will be easier with one coil.  If any of them work, I can do it to the additional two pickups.
I will let you know as always,
Bruce
http://energyfreedomreport.com
Bruce_TPU
Edit 1:
All of my Brooks coils have a seperate bias winding on them.  I have not wired or tested them... until now.  New Voltage One Coil: 2.9 volts
Bruce_TPU
Evening All,
Well, I have learned much tonight.  I did not even get to the experiments with wrapping the brooks, because of so many other things I was trying.
For best results, I think I will need to wind my new toroid that will fully saturate and test with those.  It is extremely sensitive.  put a magnet the wrong way, cut your output by half, etc.
@Mags,
I think the best bet to make this work into OU, is to wire SEVERAL toroids, that saturate, in series with one another.  Have each one "power" a pickup coil, and make these into a toroid itself...HEY, that looks like JLN Labs graphic then...LOL  Wire some more Mags and put them in series.  Play with the magnetic pole orientations, and make sure your toroid is saturating.  Best advice I can give.
Pictured below is my one coil SSG1.  Hand turned even at super slow speeds.
Cheers,
Bruce
