Solid State Orbo System
Magluvin
Bruce
Well, if you get it to resonate, then you should be able to get another tank of the same to resonate by 1 wire between them. But then your still at a point as to how to get it out for use.
try a cap in series with the led. Like a 10 to 20 mfd NP cap. When I capture bemf of like 200v, I get less out by diode alone. But when I add a cap to 1 leg, in series with the diode, I get more, kinda tesla style. =]
Mags
Edit  Actually maybe not in your case. This will work though...
1 cap on each leg of the coil and the other ends of the caps to a bridge, after the bridge put the led, even add a cap to stabilize the out from the bridge. For some reason the caps ease the output as compared to direct rectifiers.
Hope that makes sense. If you would like me to do a vid, just say the werd. werd  =]
synchro1
@Bruce-TPU
                Just a reminder that the natural oscillating frequency of magnetism is estimated to be around 159 Hz. JLN is pulsing his toroid at 200 Hz with a duty cycle of .75. 53 Hz would give you a one third harmonic, not a bad choice of range for pulse frequency. Your progress so far has been leap frogging at a dizzying pace. Your attempts to harness resonance very promising. Breakthrough looks imminent.
Bruce_TPU
Quote from: synchro1 on February 28, 2010, 11:00:33 AM
@Bruce-TPU
Hi Synchro,
You are correct about JLN Labs.  They are using a freq gen to pulse at 200 Hz.  BUT...and this is the big but, I am simply switching on/off the toroid, so can it be switched in the KHz range and still work?  If yes, I will be able to produce as much power as I want.  If no, then the question becomes, what is the MAX switch rate it will work at?  If I find that, then I can work backwards from there.
Today I have some weird experiments planned, using the pickup coils.  I will let you know if any work.
Cheers,
Bruce
http://www.energyfreedomreport.com
synchro1
@Bruce,
          Increasing the pulse frequency into the best harmonic KHz range can be determined by testing with a potentiometer, but I believe the harmonic is a function of threes and nines, not a decimal progression.
Bruce_TPU
Good Evening ALL,
The day started off slowly, but then a couple of very cool things were discovered!
First let me say, that when we combine this very cool pulsing of the toroid, with my Brooks coils, things begin to get mysterious.  Turn the bottom outside magnet to a different pole and output drops by half (marked "up" on mag just in case...LOL)
Place a Brooks coil on top of another with the magnetic fields going the wrong direction, and output drops to 1/5....
Then we get to the cool stuff... :o
Stack the brooks one on top of another and they are a gift that keeps giving.  No matter how many I stack on top, they produce about the same amount of power.
And then, I wired ALL the brooks biases in series, about 6 ohms worth,  in series with my toroids, resistance dropped the power input and the output rose by about 20% per Coil.  If I had more Brooks coils (I only have 6) I feel I could stack them to the ceiling.
Now, what you see pictured below, is ONE MODULE, I calculated that I could have 4 modules, as I alrady have all 4 toroids in series, as this cuts power consumption.
Is it the B field of the brooks, generating power in the ones above it?  Oh, by the way, tried to stack some UNDER the bottom toroid, and no way.  Very little output.  Could be because of how I have the bottom magnet biasing things.  But, any who... Each Brooks coil is $30.00 USD.  So, before I purchase some more, what I will do, is take the CENTER Brooks on the top stack, and turn it into a Resonant Tank Circuit.  I think this might induce more power into the coils above and beneath.  If you ould feel how powerful the magnetic field is arond the Brooks coil Edges.  I held another coils vertical to the Brooks and it picked up power.
So, next step is to build and test Resonant LC in the middle, and to Build my electronic switch.  If, with the electronic switch, I can produce enough power output to have a chance to break unity if I had more Brooks coils, I will begin to buy some, borrow some, what ever is needed.
Right now I am pulsing at 50.3 Hz.    Output frequency of aprox 180 Hz and a duty cycle of 82%.  Voltage for module one SSG3 Output is 20 volts AC and aprox 250 uA  Four modules would give me 80 volts at 1ma output, hand turning a rotor for switching.  12.5 Khz might get me to OU, if the switch works to that frequency.  On/Off is all I need for now. ...
Cheers,
Bruce
