Solid State Orbo System
Bruce_TPU
Okay electronic gurus...please tell me why when I put a resistor that Ohms out at 807 ohms, IN Parallel, as my load, and check the resistance, it reads 39.6 Ohms.
Each of my 6 brooks output coils ohm out at about 254 ohms individually and ALL 6 are wired in parallel for the output.  No diodes, no caps.
If I could have some help here, to make sure that I am calculating the power factor correctly.  Thank you.
EDIT:
I tried several other resistors and could not get a resistance above 41 ohms.  All the resistors I tried resulted in about the same or a little less power.
That is it for tonight.  I have glued up some plastic pieces that I will be winding as a "center solonoid bias" to drop into the center hole.  Between it and the outer bias already in place, it should assist in strengthening the b field...we will see. ;)
Cheers,
Bruce
EDIT 2:
P.S.  Output Frequency is 48 Hz, give or take, about what the rotor is switching.  Duty cycle is 60% now.
wings
Quote from: Bruce_TPU on March 03, 2010, 11:18:00 PM
EDIT:
Cheers,
Bruce
EDIT 2:
the following formula give me 40 ohm close to your measurement.
Bruce_TPU
Quote from: wings on March 04, 2010, 01:38:27 AM
Awesome Wings!  Thank you very much.  I have got to make sure that I was not screwin' up the power calculation somehow.  I am just astounded that I am nearly at 1 Watt of power output by tweaking, and have still not yet added high speed switching.  That will be the last thing that I add.  I still have a few more experiments to try and still boost output and then there are a few things I am going to try, to try to reduce input power, while not affecting the output.
Thank you again,
Bruce
wings
Quote from: Omega_0 on March 03, 2010, 03:33:25 PM
That 10k in input is probably a copy-paste mistake. It won't even work with 10k there. See this earlier diagram, which shows a correct value of 1 ohm.
So the real input must be: (4*4*0.85)/(1+1.1)  = 6W
Naudin have updated the circuit changing the resistance in series with the toroid from 10 kom down to 220 ohm.
the new calculation give output / input ratio down from 98 to 2.2 anyway more than 1.
Bruce_TPU
Evening All,
This evening, I have added a "center" pick up coil.  I plan on setting this up as a resonant tank.
It ohmed out at 1 ohm.
It's stand alone power:
.138       V
.9          R
0.25333  I
0.02116  P
Tomorrow I am going to wind my new toroid, and see if I can put the Steorn magnet motor in series with my 1 Watt SSG3.  This will do several things for me, not the least, speeding up my switching, greatly.  ;)
I ordered many electronic part this evening.  I have three circuit to build to start with, and making my inner coil a resonant tank.
Circuit 1 is JLN Labs output circuit, this should give me more available power on my output.
Circuit 2 is a new switching circuit, that will run off of a rechargable D-cell Battery to power my SSG3 and Steorn Magnet Motor.
Circuit 3 is a Radiant Energy battery recharger, to recharge the battery, as well.
Lastly, If I see an increase in power on the output at the higher switching and I see I can get everything working on ONE D cell, then it is time to invest in six more brooks coils and to build another module.  I will have 1 more toroid not doing anything.  1 for Steorn, 2 for SSG3 Module 1, and 1 for SSG3 Module 2.  This is my plan....  :)
Night,
Bruce
