Solid State Orbo System
Omega_0
Quote from: wings on March 04, 2010, 04:44:30 PM
Naudin have updated the circuit changing the resistance in series with the toroid from 10 kom down to 220 ohm.
the new calculation give output / input ratio down from 98 to 2.2 anyway more than 1.
I still think the output is not being calculated correctly.
I guess you can't compare the rectified output with un-rectified input. Both input and output must be rectified to get a meaningful value, or use pulse integration on both input and output side. If JLN is reading this, he will see my concern.
Now about lambda,
From the traces in Episode 6, we can see that the voltage of mag pulse is about -6V (for 300us) and that of demag pulse is 3.5V (for 500us), so the lambda per cycle is =  3.5^2*500 / 6^2*300 =  0.57
(Assuming both pulses are dumped in a load of value R, which cancels out anyway)
So, I have no idea why its coming 13.7 for rectified case.
He says there - "Shorter the clock pulse (low DTC) is, lower the energy spent for the magnetization process will be.", but he is using 85% DTC in Episode 7, which is too high for this statement to be true. I have no idea whats going on here, its all so confusing :)
Bruce_TPU
Quote from: exnihiloest on March 05, 2010, 04:50:36 AM
Right. I already said almost the same. Naudin is measuring peak voltages instead of rms voltages. This gives completely false results.
It looked to me like his Output, BOTH of them is DC, nearly straightline.  So how can you say he is measuring peak voltages, giving false results?
Groundloop
@exnihiloest,
This thread is about people working on solid state Orbo like systems
and NOT about JNL measurements. If you want a lengthy discussion
about measurements errors etc. then please do it somewhere else.
Groundloop.
Rapadura
Overunity only exists when the output power can charge a larger battery than the input battery, with a larger amount of joules than in the input battery.
No need for complicated calculations.
Groundloop
@Rapadura,
I agree. The other way is to loop the output back to the input.
If the circuit is over unity then the input battery will charge.
G.
