Solid State Orbo System
Bruce_TPU
Quote from: Groundloop on January 07, 2010, 06:32:34 PM
Bruce,
Of all the crappy ideas,..............Just kidding LOL
I tested your idea. I made just a little coil onto a Ferrite tube and put the
new coil as in your drawing. And.................It worked! :-)
The generator coil did give out the same voltage as before and
the new coil was an added bonus. So now we know, three coils
on a setup like this.
Thanks,
Alex.
YES!  Very good news indeed!
Next thought is to use your frequency generator to pulse the toroid alone by it's self until you see a "drop" in current.  This will be the resonant frequency of your toroid.  I'm sure you know this, but more for those reading...LOL  Set your switching of the toroid at that frequency and your power consumption should go down.
PS. What is your power input now, into the toroids?
Cheers,
Bruce
Groundloop
Bruce,
The power input right now is zero. I just smoked my transistor.
I'm waiting for some hexfets in the mail and should have them
tomorrow. I'm working on an idea for a new switch that will
give me the resonant frequency automatic. Attached.....
Alex.
gotoluc
Great idea there Bruce ;)  thanks for your contribution.
I was also thinking ::) last night, what if we pulse one coil at a time which would allow one permanent magnet flux to enter the pickup coil at a time, would the device still work in this configuration? ... if so, wouldn't the toroid that is on not help to combine its flux to the flux of the magnet that is coming in from the open side and vise-versa when it switches to the other coil?
Luc
Bruce_TPU
Quote from: Groundloop on January 07, 2010, 08:04:42 PM
Bruce,
Alex.
Hi Alex,
Very cool circuit and idea!
You know, having now three generator output coil, all of the outputs will be able to be wired in parallel, allowing for a bump in amperage.   :D
While we await your Hexfets, we will continue to think.  LOL
Cheers,
Bruce
Groundloop
Luc,
It will work. I have tested with just one magnet and I get power.
But it will give half the power. So switching one toroid and then
the other will give 1/2 + 1/2 = 1.
Alex.
