Solid State Orbo System
Bruce_TPU
Quote from: Groundloop on January 06, 2010, 12:45:19 PM
Ben, Bruce,
Thanks. :-)
I will continue my work in here. That way we do not have to clutter up the other thread.
I have not tested the flux bar from magnet to magnet yet. But I do not think it is needed.
My research shows me that if the magnet field is too strong then I need a huge current
going in the toroids to block that field. There is a balance between magnetic field and
the power needed in the toroids.
Alex.
Could you not build some sort of switching device that will only allow the steel from one side to the other to connect ONLY when there is no power to the toroids?  This would be like a flux booster and yet when the toroid is turned on and is in "blocking mode", it is only having to block the same flux it is blocking now.  Just a weird idea, I know... but that is me!  LOL
Cheers,
Bruce
Groundloop
Bruce,
Everything is possible. I have tried to explain the problem with
too strong magnets on the toroids. There is a limit to the toroid
cores ability to shield the magnetic field. If the field is too strong
and if we already are powering the toroid cores to the saturation
point, then all power increase after that point is wasted as heat.
A cross bar at the magnets will make the field so strong that there
is not enough magnetic shielding left in the cores to overcome this.
Alex.
dradak1
That's the spirit - congratulate Alex - will be really sad that you didn't continue sharing you excellent work.
Cheers,
Dragan
Groundloop
@oscar,
>>when you wind your next generator coil, maybe you can put a centre-tap in it.
>>Then you may want to test this arrangement again:
>>Maybe you will get "two outputs" with the centre tapped generator coil.
>>measuring between each end of the generator coil and it's centre.
I have tested the NN and SS magnets arrangement on my toroid ends.
I measured zero (or very close to zero) voltage between the generator coil
ends and also between the center taps and the ends.
Alex.
Groundloop
@dradak1,
Thanks.
I think it is important to also research the magnetic shielding effect.
Any more builders on this system?
Alex.
