Solid State Orbo System
Bruce_TPU
Hello ALL,
And then there were two...
And my DC to pulse width converter kit arrived today!   :)  I hope to be building it over the holiday weekend.  Lord willing...
Cheers,
Bruce
teslaalset
wings
Quote from: teslaalset on April 01, 2010, 03:28:50 PM
The Orbo solid state:
http://www.steorn.com/orbo/solidstate/
.....Solid State Orbo gains energy via control of a material's inductance and domain rotation. As with all previous implementations of Orbo, these material permeability effects are fundamental to the production of an energy gain. .......
3 coils 1 toroid  ???    1 shaft or 2 magnets?
1st April 2010?
NerzhDishual
April fool's day???
Not so sure....
Should be Sean McCarthy's puckish sense of humour.
From the Steorn forum:
http://www.steorn.com/forum/comments.php?DiscussionID=62996&page=1#Item_29
"007
uphillcastle:Babcat why do you believe in it so much are you not telling us something?
Why announce this on the 1st of April?????? its just asking for trouble
Don't you get it. Steorn love doing this kind of shit. I personally think it's hilarious that they have THE most significant technology ever released and that they still have the time to take the piss out of pseudosceptics.
Welcome to the era of A."
Nolite mittere margaritas ante porcos.
gravityblock
Quote from: NerzhDishual on April 01, 2010, 05:50:46 PM
April fool's day???
Not so sure....
"007
Actually, the video announcing the ssOrbo was released on March 30, 2010 and not on April 1, 2010, http://www.youtube.com/watch?v=evIZy72uCRc  Around the 57 second mark of that video, it shows software setup to handle two different frequencies, two different duty cycles, etc.  ClanZer's ssOrbo replication is also showing this, http://www.overunity.org.uk/CLaNZSSpanel.jpg  This is more than likely used to create an asymmetric system.
They are also releasing a lot more information into the Public Domain, including the PM Orbo, eOrbo, ssOrbo, calorimeter tests, asymmetry and energy in a magnetic system.
This document from Steorn, http://www.steorn.com/images/asymmetry-and-energy-in-magnetic-systems.pdf , sets out to demonstrate that such asymmetry in itself does not lead to unexpected energy results, but that a combination of asymmetry and non-linear MH relationships does indeed lead to unexpected energy results.
GB
