Solid State Orbo System
Bruce_TPU
Hello All,
Well I have just completed my first test with my new pulser, and no where near OU... but I learned a bit new.
First, the sweet spot seemed to be between 71 Hz 80 Hz.  Above 112 Hz and the polarity of the current flips, and I have to reverse the inputs into my analog meter to get a correct reading.
As the frequency increases, the output voltage and current both decrease.  I had hoped that increasing the frequency would increase the output current, but it did not happen, but actually the reversed.
At between 71 and 80 Hz, there is tremendous vibration in the toroids and unit.  The SSG3 sounds like an airplane coming to power as the frequency increases.
I am powering the board with a 9 volt battery, and the main power in is my 12 volt 7aH battery.
This pulser uses far more power than my old set up.
A second test will be forthcoming in a few weeks.  I have ordered a new prototype pulser and it is being built for me.  I needed these pulser's anyway for future experiments, so it is all good.
I have learned a great deal building this.  Steorn's approach is still the best...IHMO.  I will leave the SSG3 built, until said new pulser arrives.  It will go up to 300 KHz and requires much less power to operate.
Max power output was 5.5 volts at 4 microamps at 49.3% duty cycle.
Cheers,   ;)
Bruce
Energy4All
Elagently simple design Groundloop. A suggestion with a cautionary note; would be to try an input pulse signal of the frequency of the earth EMF. Please do not physically come into contact with the device though.
Groundloop
@Energy4All,
What is the frequency of the earth?
Do you mean the Schumann resonances?
(Schumann resonances are the principal background in the
electromagnetic spectrum between 3â€"69 Hz, and appear as distinct
peaks at extremely low frequencies (ELF) around 7.83, 14.3, 20.8,
27.3 and 33.8Hz. The eighth overtone lies at approximately 59.9 Hz.)
What will happen if I physically come into contact with the device?
Thanks,
Groundloop.
synchro1
Two aperture wraps one at ten and the other at the two O'clock position, and two output coils on each side of the Toroid, magnet stack down the center, duplicates Colonel Bearden's MEG to a T. His twin flux blocker coils were wired in parallel with the inside coil wraps connected to the negative and the outside wraps with the coil ends connected to the positive pole of the power source. A switch is wired on each end. A standard flip flop with a power pot should get the kind of results Bearden's MEG demonstrates, only the COP should be hundreds of times greater due to the great reduction in scale of the input coils. This works by directing the flux away from one half of the toroid at a time causing alternating cycles of demagnatization in the core material. Simple way for Bruce to put one of his extra circuits to work.
Energy4All
Hello Synchro1. I would start with the lowest frequency and work your way up on an experimental basis. If you run into a particularly strong magnetic frequency there I can only theorize that the device will pull your two permanent magnets into your output core and or allow for such an inrush of magnetic potential that it could result in a brief; but large current increase in the device. In theory what I am trying to get you to see is that you could tap the earth magnetic field if you view the device as a magnetic pump directly coupled with the earth magnetic field. This is just theory; but does pose questions and as yet unknown factors.
