Solid State Orbo System
gyulasun
Hi Folks,
There is another book: The_Hendeshot_motor_mystery.pdf in this Russian thread here, freely downloadable from the first post, (the book is in English):
http://www.001-lab.com/001lab/index.php?topic=143.0
Sorry if this was already known by you.
Gyula
Energy4All
Thank you Gyulasun. I'll look it over and see if it is any more revealing than the version I have already covered. I believe I already understand how the motor works; but I always investigate other documents on such obscurred devices.
Jimboot
Quote from: smoky on April 10, 2010, 04:14:36 AM
@Bruce_TPU
Hi Bruce I think you're onto something important with the Aluminum.
Floyd Sweets VTA was constructed with an Aluminum box around the coils.  Dr James Schwartz uses Aluminum sheet cut out around wound magnets (and Bismuth) in his ERR.
My best guess is it might introduce a flux reflection like a mirror by intercepting a rising flux.... turning it into an induced current & the resulting current flow in the Aluminum then produces it's own flux opposing the original flux.  So the polarity is identical but the direction is reversed on rising fluxes.
When the incoming flux tries to reduce the polarity reverses producing an attraction flux opposite to the original flux.
This is easily seen in the various Youtube videos where they drop a big Neo onto a Copper or Aluminum plate.  It falls in slow motion due to the incoming rising density flux.
However if the Neo is slid around close to the plate the plate tends to drag along underneath the Neo due to the falling flux.
So overall I believe there's a 90 degree phase shift in incoming to reflected flux occurs.
(When plotted one against the other, assuming the incident flux to be sinusoidal in nature).
For what it's worth there is also the Boyd Bushman experiement where he levitates a by putting 110 V through a coil that sits on top of an Al plate. Only works with the plate tho.
gyulasun
In most of the cases, like in Boyd Bushman coil levitation over an Alu plate, eddy currents are induced in the metal and the flux created by those currents works against the flux of the coil current.
Eddy current heats the metal bodies in which they flow.
Just found an interesting book on its effect on non ferromagnetic metals:
http://www.scribd.com/doc/30473500/Non-Ferrous-Magnet
rgds, Gyula
wings
Quote from: gyulasun on April 26, 2010, 06:51:39 AM
rgds, Gyula
nice ...
same user from chadj1060's Documents:
http://www.scribd.com/people/documents/5980480-chadj1060
Seike Ultrarelativity
Advanced Energetics II
and GB Patent application 2130431
Method and means for producing perpetual motion with high power
http://www.scribd.com/doc/27845874/GB-Patent-2130431
try to find it in internet ...
