Solid State Orbo System
Energy4All
Indeed it does E2Matrix. As an aside. Having read over this patent and understanding the mechanics involved I am impressed with the Fractal Mathmatics aspect of this device with respect to a macrocosmic version IE: our own solar system. I did ask the Alpha Institute for Advanced Study to analyze this device. I do not know if they will as they never responded to my request.
Paul-R
Quote from: e2matrix on April 27, 2010, 03:20:01 PM
Interesting patent grant on a perpetual motion device.
Its not a grant; its an application. And with a priority date of 1983, it must be out of date.
Interesting.
Omega_0
I heard that about a dozen SS orbos are being built and tested.
Some engineers have started a new blog to blog the progress here :
http://www.iol.ie/~inscc/My_Orbo_Blog/Welcome.html
http://www.iol.ie/~inscc/My_Orbo_Blog/Blog/Blog.html
These guys must be familiar to many posters here.
You may get some info in pieces, like the ssorbo has 3 solenoids and 1 toroid and uses rotating magnetic fields. He said he will publish the results.
Groundloop
@All,
Do you remember the Radiant Voltage Amplifier from page 43 in this thread?
I have decided to make a scaled up version of that circuit. Attached is the
design and build so far.
Part List:
T1 = NTE2354
C1 = 2,2uF 630V MKP
D3,D4,D5,D6 = KBU1004
R1 = 10K 5W
D7 = BAW62
RG1 = L78S10CV
C2 = 100uF 16V
C3 = 1000uF 63V
SW1 = ON/OFF
D1,D2 = BYV29-500
Fr1, Fr2 = 2 x "C" Ferrite Cores with 2 x I beams.
L1,L2 = 200 Turn 0,7mm Cu.
L3,L4 = 80 Turn 0,7mm Cu.
L5(L6) = 80 Turn 0,7mm Cu.
Coils done! Next is connecting coils to board and then first test run.
Groundloop.
Groundloop
@All,
OK, now I got the circuit up and running for the first time.
I'm running from a 9V NiMeh battery first just to be sure
that everything is working before trying out on a lead acid battery.
The 9 volt battery holds 8,4 volt and the AUX AC output was 12,5 Volt.
The next job is to make sure I got the polarity of the L3/L4 coils
correct. Then I will be ready to test on a lead acid battery.
Groundloop.
