Solid State Orbo System
Groundloop
Hi Topper,
I did use 4 wires in parallel 0,2 mm enameled copper wire. Did put as many
turns as I could onto the cores, approx. 90 turns, if I remember correct. So if
you use 0,8mm enameled copper wire you will have the same approx.
coil. Have fun. :-)
GL.
tagor
another product from steorn the HephaHeat
http://pesn.com/2011/11/08/9601951_Steorn_Announces_HephaHeat_Oveurnity_Technology/
Quote from: Groundloop on November 08, 2011, 03:32:41 PM
Hi Topper,
coil. Have fun. :-)
GL.
tagor
now there is a lot of devices that gets real overunity !
this is an evidence that you are wrong
Quote from: exnihiloest on October 12, 2010, 06:58:54 AM
This statement is verified neither by measurements nor by a theoritical analysis.
A ferrite is saturated only along the saturating field (a toroid coil saturated by a well balanced transverse field keeps the same inductance). This means that the saturating field must have components that superpose to the field that we want control. Therefore the sources of the two fields are coupled and interact on each other. The work done to control the direction of the magnetic domains by the saturating field opposes the work done by the controled field, the laws of conservation (momentum, energy) and Lenz law still apply.
Groundloop
verpies
Why did this thread die?
No post for a year!
