Solid state version of Sprain motor..understanding how it works...
Started by hartiberlin, March 18, 2006, 09:38:18 PM
hartiberlin
Actually what you see as the red lines in this toroid
will be the magnetic vektor potential A-Field .
The magnetic flux density B-Field would go round in it as the blue B-field
shows here as the direction in one point.
But it would also go in circles inside the red A-field like in a toroidal transformer core.
Nowif you change the radius r or diameter d of this magnetic toroid you can get an
electrical induction inside a pickup coil wound around this toroid or
inside pickup coils where this toroid moves through ,
accelerated by permanent magnets !
So if such a toroidal field can travel inside the air it could
also be attracted and accelerated by permanent magnets and
pickup coils could induce an output current when this toroid
goes through them.
This is the whole idea !
hartiberlin
One question:
If the red A-field in the graphics above would just rotate clockwise,
but not shrink or changing in any other way, would this also
induce a current in a coil that would be in the same spot ?
Our actual motor/generator experiment :
the generator-coil in a cage
test XXX effect:
input? ? ? ? ? 6V/0,18A? DC? ? ? 23V/0,6A? DC?? ??6V/0,5A? DC
output? ? ?6,6V/3,00mA? AC? ? 135V/1,5mA? AC?? 10V/7,0mA? AC
Scratch materials !!!
Sincerely
? ? ? ? ? ? de Lanca
p.s.:Go to your repair-shop,ask for washing-machine encoder !!!
? ? ? I know,an unkonventional kind of generator but useable
? ? ? and for cheap experiments functional? !!!
Average of motor/generator cage-coil efficiency:2%
Demonstrating a success ?
Yes,the demonstration shows the difference between nominal and real efficiency,
the combination of commercial micromotor/microgenerator let
us receive an average of 10% !!!
Mathematical/logical we would have to get 49%(70%motorX70%generator)
as "IDEAL Transformation Result" !
A conventional transformer give us a 90/95 % efficiency !!!
These experiments are the base to understand the different results between
the publicated? Ramon Huth(DE10151067)/Li Yng Tian(DE4402337)-Patent object describtion
and the conventional micro-motor/generator combination !
In search of "Factor 10" !!! Quantum- Neurologic,something between
Paretto Pyramid?(Relativitaet/Relativity) -and Iceberg Theory(Schwerkraft/Gravity).
Sincerely
