Earth Battery Beneath Power Lines
Started by czimborbryan, January 17, 2010, 12:58:09 PM
czimborbryan
If an Earth battery were to be constructed beneath power lines, would it recapture power lost by radiation?
the_big_m_in_ok
Quote from: czimborbryan on January 17, 2010, 12:58:09 PM
The frequency of the overhead lines and the earth's natural frequencie(s) are different.  If I'm not mistaken, unless there's some frequency resonance, there should be no interaction at all.
--Lee
Pirate88179
Quote from: the_big_m_in_ok on February 04, 2010, 09:10:51 PM
--Lee
I agree.
jadaro2600
As I understand it, the draw from the line is insignificant amounts of current with moderate amounts of voltage.
I would try this, but I fear controversy.
I think the idea would be to use a coil for a source, and an iron rod which is grounded, I suppose you would need to place the coil parallel to the line, and have a wire off the core to ground.  This may help conduction, but any significant losses CAN be detected by the power company, ..so installing something permanent is a bad idea ...for experimental purposes..
and legally, ..honestly, anything transmitted via radio waves is technically up for grabs, regardless of whether or not it loads the transmitter, the transmitter assumes that the waves will be harnessed by something, therefore, ...it seems logical that the electromagnetic energy from it is intended to be free.
Good luck arguing that though, ..audio is one thing, hertzian chaos is another.
We are subjected to it, therefore we should be able to utilize it, otherwise it is unwanted, and therefore harassment of sorts.  Such things have to be proven with malice, though, and intent.
czimborbryan
Ahha, jadaro2600, you get my point.
Instead of drawing more power from the lines than what would normally be radiated or lost, I would like to recover the loss  -  for free and in no way be taking anything that wasn't lost to the electric company to begin with.  Kind of like scavenging the decomposing energy that runs over my property.
