All of Stanley Meyer's Equipment FOUND Including Dune Buggy! (Videos Here)
Started by chessnyt, January 19, 2010, 03:16:34 AM
MarkE
If the circuits do what you want and especially if you have them built then there isn't any good reaon to change.  Maybe if you were selling kits you might want to get out of the MSI logic.  The good news is that 4000 CMOS is slow and tolerates asynchronous  logic fairly well.
ARMCORTEX
MarkE, how do you like them big boasting, big boating, projects of mine.
You think you could handle a piece of this large pie I wanna make?
MarkE
My personal opinion is that Stan Meyer was as the Ohio judge said:  an "egregious fraud".  I am not interested in pursuing his claims myself.  But if you want design help with experiments that you are going to set up and run I can help.  Is there anything that the present circuit doesn't do or doesn't do well that you want to address?
ARMCORTEX
the circuit works in 74hc just the same but the output of flips flops has to be inverted if I remember.
http://www.techbriefs.com/component/content/article/1264-ntb/tech-briefs/electronics-and-computers/1839
Output from switch capacitors has steps that need filtering
Beyond the whole massiveness of it and need for tight component tolerance for the filters for phase precision (really ?)
transformers also, I expect you will ned 50-100 volts, Stephen Meyers didnt use very HV (28 I believe), wich helps the transformer construction
I say construction  because buying wide band transformer is expensive.
there is many stages of annoying voltage regulators also, because the amps need to run, and drive the 12v mosfets @ about 8 volts higher on gate.
I anticipated I needed 22v dual rail power supply.
let me seek the pcb.
I must identify it, its a big one, I work in a way where nothing is identified.
the dc pulser, works marvellously. Try it on sims using the gate protection with 2 totally independant gate and pulse.
Cap-Z-ro
To clarify a point made in this thread over and over:
The jails are full of fraudsters and criminals deemed so by so called "judges" in a morally and ethically corrupt system set up by murderous satan worshiping pedophiles.
Carry on.
Regards...
