"Tiny Orbo Replication" over 100% efficiency
Started by PaulLowrance, January 27, 2010, 12:17:55 PM
PaulLowrance
It's difficult to tell how many segments are included.  Very few are clear. For example the following item says, "Price is per set of four pieces," but it's $9.75,
http://www.supermagnetman.net/product_info.php?cPath=37&products_id=1370
PaulLowrance
This item shows 6 segments, yet the text says, "Arc segments for motor - OD-31.94mm, ID-27.94mm, 6mm wide. 12 pcs to make a circle. 1 Set includes 14 magnets (1 extra for each pole up to 4 sets)."  So what's the price for a "set"?
http://www.supermagnetman.net/product_info.php?cPath=37&products_id=323
0c
Quote from: PaulLowrance on February 16, 2010, 01:21:09 PM
As I said above, contact George. He will happily answer any questions you might have. I bought mine a couple years ago from his "clearance" page and they are no longer listed. I don't have any personal knowledge about the magnets listed right now.
Here again is his contact information:
http://www.supermagnetman.net/contact_us.php
ETA: You can also watch hs videos at:
http://www.youtube.com/user/SuperMagnetMan#p/u
Some of them are very educational.
PaulLowrance
Oc, can you show a video of your magnetic levitation bearings spinning?
0c
Quote from: PaulLowrance on February 16, 2010, 01:56:25 PM
Oc, can you show a A of your magnetic levitation bearings spinning?
I don't have anything that does something useful, just a crude proof-of-concept juryrig setup that I assembled in a bench vice. All I have is 2 wooden blocks with bored holes and arc magnets glued into the holes, N poles in one block and S poles in the other.
For testing, I placed the blocks into a bench vice and used a 3" long rod magnet as a spindle. I held the rod magnet in the center and tightened the vice until the ends of the rod stabilzed in the center of the ring. It worked but was axially unstable. Just a slight axial force and the spindle would shoot through until it was forced against the bottom of the hole.
I haven't put the effort into it to stabilize things to make it usable, and haven't touched it for a couple years. But I'm confident there is some way to stabilize it.
