Building DS Plasma Globe
Started by h2ocommuter, January 29, 2010, 02:49:18 PM
h2ocommuter
Quote from: Paul-R on January 31, 2010, 08:44:42 AM
Take a look at these. The globe has been discussed. I point out the two circuits interlocked by a transformer which all need to resonate one with another:
http://www.overunity.com/index.php?topic=4233.0
http://www.overunity.com/index.php?topic=502.0
http://www.overunity.com/index.php?topic=7837
Paul-R
I stand corrected.  I have been on other forums and  different threads commented there, I stand by starting this thread as a plasma globe research area.
No condemnation meant, I do appreciate your links.  Wings has done some wonderful things with his globe.
I am doing everything to keep abreast of what is and has been discovered about DS work, and the plasma globe in particular.
h2ocommuter
@Magluvin,
I am pretty much oblivious to the correct nomenclature when it comes to electronics so I will tell you everything I am using so you can decide what I have operating my circuit.
I am using an NTE 125 SI general purpose rectifier 1000V max  50A max and the LED is a 18mcd - 5mm linrose super brite B4304H5, 2.15 Vf @ 20ma
@ FatBird,
The up and down I read on my meter is at the top end of the charged caps. That is to say my plasma globe will not add any more voltage to the high value of the charge therein.
This video is showing how fast the caps are charging with a considerable amount of voltage.
I tested the amperage on the discharge of these caps today  "under 200 V", and this measurement is well over 300A.
This reading is being picked up using a 400 Ampere analog meter.  I'll send video shortly.
http://www.youtube.com/watch?v=KCYaFdHQYuI&feature=channel
@ all,
As I am trying to really understand what in the world is going on with All of this magnetic flux jargon, The Static electricity,,, And whatever is actually coming from the L-2 on top the plasmaglobe. and my circuit......
I guess it is not important at this point, being as I really have nothing yet.... but if I get something for the 30 watts my plasma globe uses to run. I hope someone will explain to me how and what my circuit is doing.
innovation_station
pretty kool topic ...
bet this is a TESLA toy !
need a pattend?
lol
is that a blowen bulb will ?  1 wire in the dirt?   lol
lol
W
h2ocommuter
OK,
when trying to get various readings on the amperes during discharge of the caps around 15 joules I took a jolt through my ring finger. this shock felt like A/C the pulsing feeling was there. I did not like that too much so I put it in a J-box and isolated the risk.
By the way using this setup, "with the first circuit"; now called the "A" circuit; the ccw 6 turn L-2, the amperes is 1 1/2 times the voltage stored in the caps. More testing to reduce the amps will continue.
I know at this point I can get the voltage and the amperage to run my 12KVA isolation transformer. the next step will be driving the discharge pulses through the IT. Induction at this point is a no brain-er.
I am going to figure out how to build another circuit that will discharge the caps in a closed system. No need to use it to power anything.  The induction is all that we need to do to the isolation transformer to work. As per Dons' directions.
Clearly defined goals, obtainable objectives. God speed. health and happiness. best wishes....
