IST`S HIGH OUTPUT 0 ZONE GENERATOR 12VDC
Started by innovation_station, February 01, 2010, 10:40:58 PM
innovation_station
WELL YES YES ANOTHER TOY!
FROM MY SIMPLE COIL ...
THIS THING 0ZONE YA OUT IN 2 MINUNETS FLAT!
DAT THING IS QUICK!
I WILL DO A VIEO ON IT TOO   I ALREADY DID BUT
I WILL MAKE IT A BIT BETTER ...  BY   ADDING WIRES TO IT ...
its SELF RECHARGEING TOO  PLUS IT HAS SECONDARIES ...  WICH POWER GROW LIGHTS!
WHOLE LOTTA LOVE !  BABY!
FIRST YOU GONNA LEARN TO PLAY IT ON GUY TAR MAN!
http://www.youtube.com/watch?v=isq8ZQSgnBs&NR=1&feature=fvwp
THEN YOU ALL GONNNA SING ALONG!
http://www.youtube.com/watch?v=zB_DOA2AL7Q&NR=1
W
jadaro2600
Wonderful; can you estimate the voltage it produces? I would like to make one of these.
innovation_station
I WOULD SAY WELL OVER 2000V   MAYBE 30 000
I HAVE NO TOOLS TO MESURE SUCH OUTPUTS!
BUT SHE STINKS UP A STORM ...
I PUT IT ON THE SCOPE 1OOV PER DEVISION
and i almost blew it up ...  so
i could only guess at the output voltage   secondaries  gonna be 500v there bouts .. will lite un modded led lights loa right out of the pack!
i will make a new coil  the same  way and video it in pictorial olny ..  im sick of the talking bit ...
then you can watch then go build it   and you will have the same results ...
but i put a lot of secondary wire on it ...  miles !  28 gage magnet wire ..
H
wattsup
Just make sure you don't breath that shit. It is pretty potent stuff.
jadaro2600
Quote from: innovation_station on February 01, 2010, 11:52:20 PM
H
Measuring high voltage is simple really, all you have to do is create a series of capacitors of like makeup.
Say, 12 1kV ceramic disk caps will be able to safely measure 11-12kV ..all you have to do is measure the voltage across one of the capacitors and multiply this times the number of capacitors.
I would recommend 14 3kv in series (42kV) ...then measure the across one of these, as series capacitors will divide the voltage safely, when they are all the same, then the math is simple.  If you have these you are still limited by the DC, the voltage reading on most DMM's is 1000v max. ...so, using 30 1kV caps could get you 30kV or, to be on the safe side, 31 1kV.
The series strip becomes a tool for determining the over all voltage of the output ( DC measure ).
Axial capacitors are probably more appropriate for this type of high voltage, as the electricity may want to arc between leads ( so spread them out a bit ) or use shrink tube to help prevent such things.
