The Ossie motor
Started by robbie47, February 02, 2010, 03:53:17 AM
captainpecan
@ solinear,
While I do agree with pretty much everything you just said about financial feasibility of clean energy technologies, I do think it is a bit premature to include the work of the Ossie Motor into it at this stage.  There is much more work to be done, including COP measurements, and using the torque to generate energy also.  We are simply not close enough to include this work in your analogy.  Afterall, MOST mone spent on research for free energy devices has no return on it all.  That's just the nature of research and prototyping. But I do feel it is very much worth the few bucks to keep working on it.
As for your comment on leaving the multimeter connected to the battery.  You are thinking exactly like I am.  In fact I already learned that lesson a couple years ago with some capacitor experiments I was doing.  I had left a 0 volt capacitor hooked to a multimeter that was turned off overnight.  The next day I ended getting bit by that cap when I grabbed it wrong.  So I tested it out, and the multimeter actually was charging the capacitor up to 9 v.  This was simply because the multimeter was using a 9v battery.  Does this happen with all multimeters, I have no idea.  I just know it did with mine, but mine were not Fluke meter's either, just simple cheapo's.  And I am still using cheap meters.  So I do believe it will probably charge the battery directly in the right scenario.  Is that was is going on with Jimboots?  Don't know, just wanted to share what I believe is happening in mine.
I am not sure why it does not seem to do it with rechargeables though?  It seems to only be doing it with disposables.  Maybe it is something to do with the internal resistance of the battery?
Jimboot
@CP No probs. I got my bridge circuit running last night. No resistors atm in it tho. Back on the D cell that ran for 100hours it has been going about 8 hours now doing 300RPM. I'll disconnect the meter now and duck back home at lunch time. Man I missed this thread last night when the site was down! If it happens again you can reach me thru my Youtube channel or twitter @jimboot. Also if you just Google "ossie motor", you'll find me :) Hope to catch up on some of the other reps today.
CP thanks for confirming the battery differences. I felt at one run even my scope hooked up was somehow consuming power. I don't think this current setup is tuned for charging yet maybe just low voltage drops. I'll know in a few hours. I've tried silver oxide, lithium, NiMH,SLA, alkaline & bog standard. I get the best results with last 2.
captainpecan
Quote from: callanan on February 08, 2010, 04:34:39 PM
Many more things can be done with this motor once we start looking at the battery differently.
Would this then mean that an earth battery could run this motor indefinately as well?
That's a very good point.  I was thinking about once I get a bit further with my setup, I was going to try the earth battery.  I have noticed on many documents discussing bedini's work over the years, there are many indications of an earth ground that most don't notice.  If he was getting good results, then I see no reason why the same concepts would not do just as good or even better with the Ossie Motor.
woopy
Hello all
what an intersting thread here  full of variable
theres is now 2 congigurations of the coils polarity
1-
the serial one that is for a 4 coils device   - + - + - + - +    which is the original Ossie's device and in this case , if you shortcut the coils you get a very strong BEMF and strong braking of the rotor, I say it is impossible to free wheel the rotor by hand.  And so far i understand,  in this config you have to tune the reed to insert the pulse motorising energy INSIDE the generaitve AC curve.
  And in this case we have to know if the AVERAGE generative energy can overcome the  TOTAL input energy ??
with this config,  on my really crude testing , i  am not able to get more than an average 15 % of generative back energy  have you better results ??
2-
is from Jimbot 's  contra serial config with - + + - - + + -  where the coils are facing eachother. In this config the rotor can be almost free wheeling with shorted coils.  And the extra energy comes only from the kickback spikes  In this config the BEMF  is almost zero  and on the scope a small trace is there but nothing to do with the generative trace.  But the kickback trace are very impressive.
And in this case we have to test if the very strong but very short Spikes (up to more than 200 volts) CAN BE TRANSFORMED in energy to overcome the input energy.
Yep !!!
good night
Laurent
Jimboot
Nice looking rig CP. HDD rotor?
