The Ossie motor
Started by robbie47, February 02, 2010, 03:53:17 AM
gyulasun
Quote from: futuristic on February 14, 2010, 11:32:24 AM
And I would go with the top design because airgap betwen coil and magnets can be less than in bottom design.
Hi Frenky,
I would like to understand why you think so,  I have read your next letter on this too (Reply#222) but I do not get it.
If I see Laurent's both drawings correctly, then assuming for both we would use the same coils, magnets and the same distances I think we would get the same torque.  And both designs let the same distances and material use, don't they?  Maybe I miss something, please tell.
I agree, the smaller the distances between the two facing magnets, the bigger the torque can be, this would involve using very flat / thin coils.
By the way, Laurent first drawing recalls Garry Stanley's pulse motor setup, and if I remember well back to 2003 or so you also built it, right?  Or was that guy another 'futuristic', I do not know. Sorry if I am mistaken.
Nevertheless, Garry used about 10mm gap between the facing magnets and he took the pancake-like air core coils from old floppy disk drives back then. And he used two such coils, the thickness of one such coil was 3-4mm, and he sandwiched two such coils one over the other as the stators, thus the total coil thickness was max 8mm, just passing between the facing magnets. He connected such two coils in parallel and he had 12 such coil pairs and 12 facing magnet pairs. The 12 (parallel connected) coil pairs (24 air core coils alltogether) were connected in series and switched on and off together by a power transistor from a 96V battery bank. He stated a COP of around 1.6 but unfortunately he never did a real torque measurement, and there were some others building his setup, but never reported real torque measurements I am aware of.
Garry always tried to explain that his paralleled coil pairs has no Lenz effect because he connected the start of one coil to the end of the other coil and vice versa (or say the + of the first is tied to the - of the other and the - of the first is tied to the + of the other) and fed them between the two start-end joint wires. He stated that by connecting them like that, in 'backwards' parallel, the induced voltages would mutually ruin each other, hence no Lenz.  This explanation was rejected by many people.
My understanding is that (say we use such a coil pair in attraction) when we switch on the current to the coil pair, there is normal backemf developed all the time the magnets are attracted towards the coil pair but when we switch the current off at the TDC, then the magnets can continue moving away freely, there will be no any further interaction against their movement.  However, I also say this is the same case for using only one such flat coil and not a pair of them. And for using one flat coil, the facing magnet pairs may get even closer, incresing flux density in the gap. The very good thing is you use both sides of the coil, no waste for one unused pole on the other side you also paid for in the input power.
rgds, Gyula
gyulasun
Quote from: solinear on February 14, 2010, 02:32:47 PM
So the coil isn't there to be used as an electromagnet (attraction/repulsion)?  If not, then I don't think it's going to make a big difference between 1 magnet and 2 magnets.  You'll get more voltage from the higher flux density on the coil, but you're also going to get more drag on the system, from the increased wattage pulled from the coils.
Hi,
I think woopy meant the coil to be used as an electromagnet, switched on at the right moment to attract the magnets and off at TDC. At least I assume he thought that when he draw those two setups and this way both sides poles of the coil are utilized.  And if this is so, then please explain if you still see bigg difference between his two setups drawn?
Thanks
Gyula
woopy
Thanks to all and especially at Gyula for taking so long time to answer my questions and each time i learn something and it is why this thread is for me very interesting.
And to be very clear.  i  am looking for something usefull and this motor  IMO has something that can be usefull. (By the way Gyula any internet link to usefull Garry's work please)
I feel the torque with my fingers and i make some comparison with high end electric motor i have    and the  effect of Lenz law is very different . I mean when i brake very slightly those very efficient motor , the current immediately climbs very high   and with my ossie very crude version, by braking the shaft,   i feel a good torque until very low RPM  and the current goes up but never so high as for standard electromotor.
That is why i will try this sandwitch config to get a strong torque with the minimum current    i don't know if it is OU and it is not my  beer at the present.
I will choose the flat coil config, because the magnets passes on the center of the coil without speed difference as it would be on the drum config
last update after 9 hours spinning   battery voltage at 4.20 volts   and supercap at 4.54 volt and Rpm between 171 and 172 RPM  I feel that the supercap pumps  all the generative induced wave which seems to be higher in votage than the battery voltage.   But of course if have to loose  a part of this stored energy  through a DC/DC converter to be able to use it  and ofcourse it is not very usefull   yet
but perhaps with sandwitch config we can get double generation of energy for the same input and in this case   !!!!!!!!!  ????????
good luck at all
Laurent
futuristic
Yes, of course it is. If the coil wouldn't be used as electromagnet then the motor wouldn't run.
gyulasun
Hi Laurent,
What current consumption do you think you have now from that 4.2V battery?
And what type of supercap do you have, make or type, Farad and voltage value?
Unfortunately Garry "disappeared" from mail groups he used to write to. His own yahoo group is inactive for years now and most of his work is there.
http://tech.groups.yahoo.com/group/Pulse_Motor_Group/
Many good info is also included by Garry in Stefan Hartmann earlier yahoo group before he opened this overunity.com site:
http://tech.groups.yahoo.com/group/free-energy/
Maybe a membership is still possible for these non-active groups, to see the uploaded relevant photos or files. I can access both if you need help.
Last week I wrote an e-mail to Garry I wanted to ask something but his earlier address is not valid any more. What is more his own website (in New Zeeland) where he originally started to publish openly his tests is already taken down. His site was at www.cable.net.nz he took it down in 2006.
rgds,  Gyula
