The Ossie motor
Started by robbie47, February 02, 2010, 03:53:17 AM
Magluvin
Hey Jim
You will have to gear the lil motor to get higher voltages from it. It will need thousands of rpm.
mags
futuristic
If you put 1ohm resistor on the small motor contacts you can measure power out.
The ultimate test would be to have motor running full speed from battery then switch it to run from a capacitor for 10 sec and have another capacitor charged from small motor.
You could then calculate the difference in energy in and out. Energy of capacitor is W=CU^2/2
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/capeng.html
Frenky
solinear
Volts hurt my head - can you measure the amps so we can figure out how many watts the motor is generating?  Please!!!!
Jimboot
Thanks @mags @futuristic @solinear Haven't measured amps but obviously way to loooow :( Have another motor I'll try tonight. I was trying to avoid gearing up given all the potential failure points.
woopy
hi all
a lot of work but really good results
my first sandwitch motor  works perfectly See pix 1 and 2
Very easy set up i took the coils of the previuos motor and glued them on heavy plastic blocs. The plastic blocs are also glued on a sand paper   so i can place  them on the  basis wood plate where i want and they stay steady. So i can tune the coils at demand  and it is the same for the rotor   so  i can get out the rotor (which is  also mounted on a CD with underneath sand paper )   very practical config to tune every thing very precisely. and allows quick modif
and now to the results
Simply really impressive
in my previous post i could report that      from  the battery at about 4.2 volts i could charge the supercap    (for Gyula  it is a serie of 2    2.7 volt 10 F super cap  = 5.4 volt) up to 4.55 voltr after 8 hours.
this evening i connected the super cap at 3.8 volt at 20.00 'oclock and  3 hours later it is already at 5.31 volts (climbing) and the battery is at 4.12 volts
I made 2 config
1-with the single Hall sensor and circuitery    the Hall circuit consume from itself under a battery at  4,2 volts about 7 milliamp  and when i find the right Hall sensor position the ampmeter shows NOTHING more than the basic circuitery   difficults to say because the amperemeter flickers between 6.4 t0 7.6  but anyway very very low  ?  This shows that without the circuit consumpton  the motor could work with ALMOST NO  current ?  OUCH ?
2- two reeds without electronic  and schottky bridge    across the coils  the best results i could get is not better as  with the electronics   but the scope trace shows an impulse that does not "eat " the induced voltage and the positive BLUE bump of my previous drawing. This is the config of the actual super cxap charging.
3- the rotor of the sandwich is made of a stack of  magnets that i have at disposal . But they are far not so powerfull than my 20 mm neo magnet that i used on my previuos test.
So i have to order more of those powefull magnets and it is very promising
good luck at all
Laurent
