The Ossie motor
Started by robbie47, February 02, 2010, 03:53:17 AM
Jimboot
@futuristic nice work. Looking forward to your numbers.
Ok I'm moving away fom the pickup coils & going back to generator attached to rotor.
I want to be able to seperate out one AA of my 5XAA pack at a time to charge & when it has charged it gets switched back into the pack & the next one gets taken out & charged and so on. Not sure how I'm going to achieve this :)
futuristic
Hi, here are scope shots. For unknown reason reed is firing also between magnets and not only on the magnet.
Next version will be with optocoupler CNY 37.
Scope shots (one on the resistor is flipped because I had probes connected wrong way)
Frenky
Jimboot
Ok gen motor is at 0.75volts 60mA. Still trying to work out the mathematics on what the Ossiemotor is actually using. It's running 2Xaa & 1Xaaa @ 3.65volt &880RPM.
Magluvin
Hey Jim
Well once you are at this point that it is this efficient, working on the generator portion is next. That where to get the Extree. Also the battery, I put a pic of a small lead acid that takes less to charge than most. As in it receives a charge more like a capacitor than other batteries.
Those mags are good size. I would try some gen coils in between the big coils. If you run them to a bridge rect. during that time in rotation the motor is not taking from the battery, so it is a good time to just send it straight to the battery. And the pickup gen coils may get some from the motor coils just being in proximity. Extree.  =]
Mags
